Crystal eye v2 tail lights
It should not be hard to determine.
Determine which light bulbs are in the new assembly [ex: running lights, backup lights, turn signal, brake light]
Determine what is the existing [OEM] assembly [ex: running lights, backup lights, turn_signal] ... I am sure brake lights are not there.
Now establish how you would get the missing energy source. ... Closest brake light source is in the hatch door --top .. so you have to tap into that.
Fishing a wire all the way to the pillar mounted lights is going to be tedious and should be avoided if possible. If you must then use the existing flex conduits and make sure you leave enough slack in there to allow movement as the trunk opens and closes.
Salim
Salim
Camera can not tell the details, but does the color of the plastic lens match well with the existing pillar mounted assembly.
Top to bottom sizes?
Mounting issues and alignment with the holes and after assembly do the lines match
If you ever get to the point where you can see the thing letup ,,, how it matches to the lit up pillar lamps.
Water proofing
Packaging
Salim
I have just ordered a set of red clear. (JDM) veeeery expensive.
I hope it is worth the money.
First I wanted to order version "1" (without running light)
These were sold out and cristaleye did not want to deliver those NEW Version 2, so i ordered it from JDM http://www.japanparts.com
im interested also for Salims Questions ! please reply.. thank you
hi vince
I've been looking for two weeks for an USA or Chinese reseller
cannot find any Shop , trader.. in alibaba.com, or aliexpress, taiwan google etc.. thats cheaper and send to international!?
and those cristaleye with turning "running lights" are hard to find for the Moment.. later i think they are on Ebay and little Cheaper later. But i dont want to wait.
first i have tried to order at: http://www.crystal-eye.jp/shopdetail...X/page1/order/
open a new account on tenso (shipping Management), but http://www.crystal-eye.jp , They had no interest to sell.. and no help is to be expected from the shop
what i found (directly from Taiwan):
http://www.twl.tw/tw/products/?method=detail&aid=5733
~ 630.00 USD + TAX ! if someone find a cheaper trader... Please publish the link
I hope the order on Japanparts.com works and the tail lights will be delivered sometime, then i can publish a full review with install an Pictures here (
I am prepared that the Tail Light Material quality will be low)
A short Info before installation in about one week..
-Today the package has already arrived (very fast from japan to switzerland)!
-The customs/local Post Office has cost me another 90 dollars (I thought it would be 100-150), 90 Dollars ..aniway too much for do nothing!?
-The package is very good, around each component is a foil
-On the backside of the tail lights are not sealed, electronic Parts (Housing with open holes), I hope the seal on the housing holds the rain off, I know I will seal it with hot glue!
- The lights are heavy and feel stable.
I think positively
ok... more after install.
I think positively
hmmm
I always thought the lens should have a seal on the top edge to prevent water entry (rain/car-wash) and must have drain. The drain is typically not a straight out (to prevent dust and insects to get in), but still have a way to drain any condensation and minute amount of water entry.
If any one wants to really seal, then make sure to seal when the humidity is very low and think about the seals around the bulbs [also bulbs may need to replaced down the road]
Salim
Salim
Thank you very much for the valuable information.
I will document the install well and take photos from the back of the tail lights..
Too bad that no other user writes about his install experience with those crystal tail lights V2 , Or I have not found anything
I thank you guys ..Bye for now
everything is installed
OK everything is installed
Those tail lights are really "plug n play"
No cutting of the other cables necessary
Quality is good!
The installation guide looks difficult with all this Japanese character. you could use google´s online translate App on iPhone, but it is not necessary!
(If you have installed it once you can only laugh that you have been afraid.)
Only the long cables must be pulled through the trunk lid and connected to the upper lights
Quality is good!
Quality is good!
Quality is good!
Are there extra 'Brake light' in each assembly and that needs to be tapped from 3rd tail light wire?
Also if you can please review [my questions in post #17]
Salim
hi salim
i have some pictures and videos on my PC (but to large to upload ..., have to resize first), i have a lot to say about this mod (my english is unfortunately not the best)
break lights are in the inner and outer assembly yes, looks much better.
you have nothing to connect to the third brake light in the middle. Only one large kabel (3 or 4 Pin´s in it) from the inner Light..over the trunk.. to the outer light.
the red colour of the tail light lenses does not exact mach with the bottom mist lights in the rear bumper.. the glasses/lens i will darken with spray..
the only lamp you have to use again are the reverse light bulps, i will change it with LED´s maybe
the housing are not exact close to the caar´s body.. nobody see that.. only if you know they are aftermarket..
I can answer any further question, (In the meantime you can order the lamps without fear)
PS: I have not sealed anything! The openings are all within the isolation inside the car!, We will see it in the next rain, at the latest in the winter
