Advice about buying RX 350 2012 98000 miles
Can someone look at the attached service record and let me know if this is a good deal or not? Seems like a lemon to me..
it has 98,000 miles and is a RX350 2012. I went to lexus website to get this information
6/8/2017
LEXUS DRIVERS
RX
SERVICE HISTORY
SERVICE HISTORY FOR: RX
VIN: 2T2ZK1BA4CC079790
96376 MILES
REPAIR# 0056929
REPORTED BY: Lexus of Las Vegas
SERVICE: PERFORM MAINTENANCE INSPECTION
DESCRIPTION: PERFORM MAINTENANCE INSPECTION
~ ~CUSTOMER STATES PERFORM MAINTENANCE INSPECTION ~ ~MAINTENANCE INSPECTION ~ ~PERFORM MAINTENANCE INSPECTION
SERVICE: PROVIDED LEXUS LOANER VEHICLE-95.00 DOLLAR PER DAY VALUE
DESCRIPTION: PROVIDED LEXUS LOANER VEHICLE-95.00 DOLLAR PER DAY VALUE ~ ~CUSTOMER STATES PROVIDED LEXUS LOANER VEHICLE ~ ~LOANER ~ ~PROVIDED LEXUS LOANER VEHICLE-95.00 DOLLAR PER DAY VALUE
92477 MILES
REPAIR# 0050467
SERVICE: REPLACE BOTH FRONT HOOD STAYS DESCRIPTION: REPLACE BOTH FRONT HOOD STAYS
~ ~CUSTOMER STATES DURING INSPECTION FOUND THAT HOOD WILL NOT STAY UP. ~ ~FOUND BOTH FRONT HOOD STAY TO BE WEAK ~ ~REPLACE BOTH FRONT HOOD STAYS
SERVICE: REPLACE LEFT FRONT VANITY MIRROR DESCRIPTION: REPLACE LEFT FRONT VANITY MIRROR
~ ~CUSTOMER STATES LIGHT IN VISOR IS OUT. CHECK AND ADVISE. ~ ~LEFT FRONT VANITY MIRROR HAS OPEN CIRCUIT ~ ~REPLACE LEFT FRONT VANITY MIRROR
89329 MILES
REPAIR# 0046109
DATE: 03/02/2017
SERVICE: PERFORMED FACTORY MINIMUM 30,000 MILE SERVICE SAME AS 60K/90K
DESCRIPTION: PERFORMED FACTORY MINIMUM 30,000 MILE SERVICE SAME AS 60K/90K ~ ~CUSTOMER STATES FACTORY MINIMUM 90,000 MILE SERVICE EST $594.94 ~ ~FACTORY MINIMUM 30,000 MILE SERVICE DUE ~ ~PERFORMED FACTORY MINIMUM 30,000 MILE SERVICE SAME AS 60K/90K
SERVICE: RESEALED TIMING COVER
DESCRIPTION: RESEALED TIMING COVER ~ ~CUSTOMER
STATES DURING INSPECTION FOUND TIMING COVER LEAKING. ~ ~FOUND TIMING COVER LEAKING ~ ~RESEALED TIMING COVER
DATE: 12/10/2016
SERVICE: REPLACE BOTH TRUNK STAYS
DESCRIPTION: REPLACE BOTH TRUNK STAYS ~ ~CUSTOMER
STATES TRUNK WILL NOT STAY UP. CHECK AND ADVISE. ~ ~FOUND BOTH TRUNK STAY TO BE WEAK ~ ~REPLACE BOTH TRUNK STAYS
DATE: 10/13/2016
SERVICE: REMOVED AND CLEANED AND CLEAR CODES AND TEST DROVE VEHICLE AND FOUND EVERYTHIN DESCRIPTION: REMOVED AND CLEANED AND CLEAR CODES AND TEST DROVE VEHICLE AND FOUND EVERYTHIN ~ ~CUSTOMER STATES ABS LIGHTS ARE ON ARE. CHECK AND
https://secure.drivers.lexus.com/lex...bel=rx&print=Y 1/10
6/8/2017
LEXUS DRIVERS
88942 MILES
REPAIR# 0044709
SERVICE: 85K SERVICE PERFORMED
DESCRIPTION: 85K SERVICE PERFORMED ~ ~CUSTOMER
STATES FACTORY MINIMUM 85,000 MILE SERVICE ~ ~85K DUE ~ ~85K SERVICE PERFORMED
83581 MILES
REPAIR# 0037291
SERVICE: DECLINED AT THIS TIME BY EXT WARR. DESCRIPTION: DECLINED AT THIS TIME BY EXT WARR.
~ ~CUSTOMER STATES ENGINE DOGBONE MOUNT CRACKED, CHECK AND ADVISE FOR LEXUS PLAT #22547789 NEED PICS FOR WARR ~ ~CRACKING BUSHING ~ ~DECLINED AT THIS TIME BY EXT WARR.
SERVICE: PERFORM EXPRESS VEHICLE INSPECTION DESCRIPTION: PERFORM EXPRESS VEHICLE INSPECTION
~ ~CUSTOMER STATES PERFORM EXPRESS VEHICLE INSPECTION ~ ~MI ~ ~PERFORM EXPRESS VEHICLE INSPECTION
81188 MILES
REPAIR# 0033860
SERVICE: NONE
DESCRIPTION: NONE ~ ~CUSTOMER STATES THERE IS A
DRAGGING TYPE NOISE WHEN DRIVING 40-45MPH FROM FRONT AREA, CHECK AND ADVISE FOR PLAT#22547789 ~ ~ROAD
ADVISE. HERS A NOISE WHEN PUSHING ON BRAKES. ~ ~FOUND LEFT FRONT WHEEL SPEED SENSOR DIRTY ~ ~REMOVED AND CLEANED AND CLEAR CODES AND TEST DROVE VEHICLE AND FOUND EVERYTHING WORKING AS DESIGN
DATE: 10/05/2016
SERVICE: OEM OIL & FILTER CHANGE
DESCRIPTION: OEM OIL & FILTER CHANGE ~ ~CUSTOMER
STATES OEM OIL & FILTER CHANGE ~ ~OIL CHANGE ~ ~OEM OIL & FILTER CHANGE
SERVICE: REPLACED TORQUE CONVERTER, AND TRANSMISSION PUMP GEAR.
DESCRIPTION: REPLACED TORQUE CONVERTER, AND TRANSMISSION PUMP GEAR. ~ ~CUSTOMER STATES WHEN GOING AT LEAST 40MPH WILL DRAG OR FEELS LIKE IT IS CHANGES GEARS AND NOT INCREASE OF ACCELERATION THEN WILL PICK BACK UP ~ ~TRUCK HAS A TRANSMISSION THAT IS SLIPPING. WARRANTY ONLY APPROVE TORQUE CONVERTER ~ ~REPLACED TORQUE CONVERTER, AND TRANSMISSION PUMP GEAR.
DATE: 06/27/2016
SERVICE: DECLINED REPAIRS AT THIS TIME BY EXT WARR.
DESCRIPTION: DECLINED REPAIRS AT THIS TIME BY EXT
WARR. ~ ~CUSTOMER STATES CONTROL ARMS BUSHINGS ARE CRACKED, CHECK AND ADVISE FOR PLAT#22547789 NEED ALL PCS FOR WARR. ~ ~CRACKING BUSHINGS ~ ~DECLINED REPAIRS AT THIS TIME BY EXT WARR.
SERVICE: REPLACED BATTERY
DESCRIPTION: REPLACED BATTERY ~ ~CUSTOMER STATES
NO START, BATTERY WAS REPLACED 11.04.13 MI:30660 RO#64038, WAS TOWED IN, *** NEED CORRECT MILEAGE****, CHECK AND ADVISE ~ ~BATTERY FAILED. CODE FTOH-JOECF- VNVM1 ~ ~REPLACED BATTERY REPLACED BATTERY ~ ~CUSTOMER STATES NO START, BATTERY WAS REPLACED 11.04.13 MI:30660 RO#64038, WAS TOWED IN, *** NEED CORRECT MILEAGE****, CHECK AND ADVISE ~ ~BATTERY FAILED CODE FTOH-JOECF-VNVM1 ~ ~REPLACED BATTERY
DATE: 05/18/2016
SERVICE: PERFORM MAINTENANCE INSPECTION DESCRIPTION: PERFORM MAINTENANCE INSPECTION
~ ~CUSTOMER STATES PERFORM MAINTENANCE INSPECTION ~ ~MI ~ ~PERFORM MAINTENANCE INSPECTION
https://secure.drivers.lexus.com/lex...bel=rx&print=Y 2/10
6/8/2017 LEXUS DRIVERS
TEST CAR NO DRAGGING NOISE NOTED. POSSIBLE BRAKE NOISE ~ ~NONE
SERVICE: PERFORMED 80,000 MILES SERVICE. TIRES 5 6/32 FB=3MM RB=4MM
DESCRIPTION: PERFORMED 80,000 MILES SERVICE. TIRES 5 6/32 FB=3MM RB=4MM ~ ~CUSTOMER STATES FACTORY MINIMUM 80,000 MILE SERVICE $226.00 ~ ~80K MILES SERVICE ~ ~PERFORMED 80,000 MILES SERVICE. TIRES 5 6/32 FB=3MM RB=4MM
SERVICE: REPLACE REAR BRAKE PADS AND ANTI SQUEAL SHIM KITS
DESCRIPTION: REPLACE REAR BRAKE PADS AND ANTI SQUEAL SHIM KITS ~ ~CUSTOMER STATES REPLACE REAR BRAKE PADS AND ANTI SQUEAL SHIM KITS ~ ~PADS WORN 4MM ~ ~REPLACE REAR BRAKE PADS AND ANTI SQUEAL SHIM KITS
SERVICE: REPLACED FRONT BRAKE PADS AND ANTI SQUEAL SHIM KITS
DESCRIPTION: REPLACED FRONT BRAKE PADS AND ANTI SQUEAL SHIM KITS ~ ~CUSTOMER STATES REPLACE FRONT BRAKE PADS AND ANTI SQUEAL SHIM KITS ~ ~PADS WORN 2MM ~ ~REPLACED FRONT BRAKE PADS AND ANTI SQUEAL SHIM KITS
SERVICE: REPLACED RIGHT SIDE CV BOOTS. DESCRIPTION: REPLACED RIGHT SIDE CV BOOTS. ~ ~UPON
INSPECTION FOUND RIGHT FRONT CV BOOT IS LEAKING GREASE ~ ~CV BOOT LEAKING GREASE ~ ~REPLACED RIGHT SIDE CV BOOTS., PARTS:431.96 LAB:528.90 TAX:35.20 TOTAL:996.06 AUTH#VSA3IZ6395
74244 MILES
REPAIR# 0027406
~ ~CUSTOMER STATES PERFORM MAINTENANCE INSPECTION ~ ~NOTED ~ ~PERFORM MAINTENANCE INSPECTION
DESCRIPTION: PROVIDED LEXUS LOANER VEHICLE-95.00 DOLLAR PER DAY VALUE ~ ~CUSTOMER STATES PROVIDED LEXUS LOANER VEHICLE ~ ~NOTED ~ ~PROVIDED LEXUS LOANER VEHICLE-95.00 DOLLAR PER DAY VALUE
SERVICE: REPLACED RF PEANUT BULB
DESCRIPTION: REPLACED RF PEANUT BULB ~ ~CUSTOMER
STATES ONE OF RIGHT FRONT HEAD LIGHT BULBS IS OUT, CHECK AND ADVISE ~ ~RF PEANUT BULB INOP ~ ~REPLACED RF PEANUT BULB
SERVICE: REPLACED DRIVERS DOOR LOCK ACTUATOR. DESCRIPTION: REPLACED DRIVERS DOOR LOCK ACTUATOR.
~ ~CUSTOMER STATES DRIVERS DOOR WONT LOCK/UNLOCK WITH AUTO KEY FOB, CHECK AND ADVISE FOR PLAT#22547789 ~ ~ACTUATOR SHORTED ~ ~REPLACED DRIVERS DOOR LOCK ACTUATOR.
SERVICE: REPLACED LEFT REAR SHOCK
DESCRIPTION: REPLACED LEFT REAR SHOCK ~ ~CUSTOMER STATES WAS ADVISED THAT SHOCK IS LEAKING, CHECK AND ADVISE ~ ~SHOCK LEAKING ~ ~REPLACED LEFT REAR SHOCK
SERVICE: REPLACED WIPER INSERTS.
DESCRIPTION: REPLACED WIPER INSERTS. ~ ~CUSTOMER
STATES REPLACE WORN WIPER INSERTS ~ ~TORN ~ ~REPLACED WIPER INSERTS.
DATE: 02/18/2016
SERVICE: PREFORMED 5,000 MILES SERVICE AT 74244 MILES
DESCRIPTION: PREFORMED 5,000 MILES SERVICE AT 74244
MILES ~ ~CUSTOMER STATES FACTORY MINIMUM 5,000 MILE SERVICE AT 74244 MILES $72.00 ~ ~5K MILES SERVICE DUE ~ ~PREFORMED 5,000 MILES SERVICE AT 74244 MILES
SERVICE: REPLACED RF DOOR LOCK ACTUATOR DESCRIPTION: REPLACED RF DOOR LOCK ACTUATOR
~ ~CUSTOMER STATES RIGHT FRONT DOOR LOCK DOESN'T LOCK WITH REMOTE, CHECK AND ADVISE FOR EXTRA WARR ~ ~RF DOOR LOCK INOP ~ ~REPLACED RF DOOR LOCK ACTUATOR
SERVICE: REPLACED RR RUNNING LIGHT ON BUMPER DESCRIPTION: REPLACED RR RUNNING LIGHT ON BUMPER
~ ~CUSTOMER STATES ONE OF RIGHT REAR TAILLIGHT BULBS IS OUT, CHECK AND ADVISE ~ ~RR RUNNING LIGHT ON BUMPER IS INOP ~ ~REPLACED RR RUNNING LIGHT ON BUMPER
67390 MILES
DATE: 11/12/2015
https://secure.drivers.lexus.com/lex...bel=rx&print=Y 3/10
REPAIR# 0020220
SERVICE: REPLACE TIRE
DESCRIPTION: REPLACE TIRE ~ ~CUSTOMER STATES THE
RIGHT REAR TIRE HAS A NAIL (50/50 PARTS WARRANTY) ~ ~NAIL IN RIGHT REAR TIRE ~ ~REPLACE TIRE
63208 MILES
REPAIR# 0015398
SERVICE: TEST DROVE VEHICLE COULD NOT DUPLICATE CONCERN AT THIS TIME
DESCRIPTION: TEST DROVE VEHICLE COULD NOT DUPLICATE CONCERN AT THIS TIME ~ ~CUSTOMER STATES TIRES MAKING SQUEALING TYPE NOISE WHEN TURNING, CHECK AND ADVISE ~ ~INSPECT ~ ~TEST DROVE VEHICLE COULD NOT DUPLICATE CONCERN AT THIS TIME
59645 MILES
REPAIR# 0009479
~ ~CUSTOMER STATES PERFORM EXPRESS VEHICLE INSPECTION ~ ~NOTED ~ ~PERFORM EXPRESS VEHICLE INSPECTION
SERVICE: RECOMMEND FRONT AND REAR BRAKE PADS, SHIMS AND RESURFACE ROTORS
DESCRIPTION: RECOMMEND FRONT AND REAR BRAKE PADS, SHIMS AND RESURFACE ROTORS ~ ~CUSTOMER STATES BRAKES MAKING SCREECHING TYPE NOISE WHEN APPLIED, COMING TO STOP LIGHT, CHECK AND ADVISE ~ ~BRAKE PADS WORN AT F:3MM R:1MM ~ ~RECOMMEND FRONT AND REAR BRAKE PADS, SHIMS AND RESURFACE ROTORS
SERVICE: REPLACE RIGHT REAR DOOR LOCK ACTUATOR ASSEMBLY
SERVICE: PERFORM FACTORY MINIMUM 30,000 MILE SERVICE SAME AS 60K/90K
DESCRIPTION: PERFORM FACTORY MINIMUM 30,000 MILE SERVICE SAME AS 60K/90K ~ ~CUSTOMER STATES FACTORY MINIMUM 60000 MILE SERVICE ~ ~MAINT. ~ ~PERFORM FACTORY MINIMUM 30,000 MILE SERVICE SAME AS 60K/90K
DATE: 09/10/2015
DESCRIPTION: REPLACED FRONT BRAKE PADS AND ANTI SQUEAL SHIM KITS ~ ~CUSTOMER STATES REPLACE FRONT BRAKE PADS AND ANTI SQUEAL SHIM KITS $409.00 ~ ~FRONT BRAKE PADS WORN ~ ~REPLACED FRONT BRAKE PADS AND ANTI SQUEAL SHIM KITS
DATE: 07/01/2015
DESCRIPTION: REPLACE REAR BRAKE PADS AND ANTI SQUEAL SHIM KITS ~ ~CUSTOMER STATES REPLACE REAR BRAKE PADS AND ANTI SQUEAL SHIM KITS ~ ~REAR BRAKE PADS WORN ~ ~REPLACE REAR BRAKE PADS AND ANTI SQUEAL SHIM KITS
https://secure.drivers.lexus.com/lex...bel=rx&print=Y 4/10
DESCRIPTION: REPLACE RIGHT REAR DOOR LOCK
ACTUATOR ASSEMBLY ~ ~CUSTOMER STATES RIGHT REAR DOOR LOCK IS NOT LOCKING OR UNLOCKING WITH THE REMOTE KEY/ OR MAIN SWITCH, CHECK AND ADVISE PLAT#20355686 ~ ~RIGHT REAR DOOR LOCK ACTUATOR ASSEMBLY SHORTED ~ ~REPLACE RIGHT REAR DOOR LOCK ACTUATOR ASSEMBLY, PARTS:309.53 LAB:116.10 TAX:25.07 TOTAL:450.70 AUTH#VSA3DK1631
56320 MILES
REPAIR# 0003865
52988 MILES
REPAIR# 0097906
SERVICE: NOTED
DESCRIPTION: NOTED ~ ~CUSTOMER STATES EXOTICAR SAID
THEY WILL SUBMIT UNDER CLAIM FOR CHARGES ~ ~NOTED ~ ~NOTED
49437 MILES
REPAIR# 0091139
DATE: 04/17/2015
SERVICE: PERFORMED 50000 MILES SERVICE TIRES@34PSI; TREAD 6/32+; BRAKES F6MM+ R CHECK
DESCRIPTION: PERFORMED 50000 MILES SERVICE TIRES@34PSI; TREAD 6/32+; BRAKES F6MM+ R CHECK ~ ~CUSTOMER STATES FACTORY MINIMUM 50,000 MILES SERVICE $239.00 ~ ~50000 MILES SERVICE ~ ~PERFORMED 50000 MILES SERVICE TIRES@34PSI; TREAD 6/32+; BRAKES F6MM+ R CHECK NEXT SERV.
SERVICE: REPLACED SMART KEY BATTERY
DESCRIPTION: REPLACED SMART KEY BATTERY
~ ~CUSTOMER STATES KEY BATTERY SEEMS LOW, IT WONT LOCK/UNLOCK WITH FIRST ATTEMPT, CHECK AND ADVISE ~ ~WEAK SMART KEY BATTERY ~ ~REPLACED SMART KEY BATTERY
DATE: 01/30/2015
SERVICE: PERFORMED ZERO POINT CALIBRATION AND SENSITIVITY CHECK ON OCCUPANT SEAT,RECHEC DESCRIPTION: PERFORMED ZERO POINT CALIBRATION AND SENSITIVITY CHECK ON OCCUPANT SEAT,RECHEC ~ ~CUSTOMER STATES CAR WENT TO EXOTICAR FOR WORK, AIR BAG SRS LIGHT IS ON, CHECK AND ADVISE ~ ~SCAN AIRBAG SYSTEM, RETRIEVED CODE B1785 (OCCUPANT CLASSIFICATION MALFUNCTION) ~ ~PERFORMED ZERO POINT CALIBRATION AND SENSITIVITY CHECK ON OCCUPANT SEAT,RECHECK OPERATION OK. CLEAR CODES
DATE: 11/04/2014
https://secure.drivers.lexus.com/lex...bel=rx&print=Y 5/10
6/8/2017
LEXUS DRIVERS
SERVICE: LUBRICATE STEERING TELESCOPIC SHAFT DESCRIPTION: LUBRICATE STEERING TELESCOPIC SHAFT
~ ~CUSTOMER STATES STEERING MAKES A NOISE WHEN RETRACTING OUT, CHECK AND ADVISE ~ ~STEERING TELESCOPIC LACK OF LUBRICANT ~ ~LUBRICATE STEERING TELESCOPIC SHAFT
SERVICE: NOTED
DESCRIPTION: NOTED ~ ~CUSTOMER STATES NEED ESTIMATE FOR TIRE REPLACEMENT ~ ~NOTED ~ ~NOTED
SERVICE: PERFORMED 45,000 MILES SERVICE DESCRIPTION: PERFORMED 45,000 MILES SERVICE
~ ~CUSTOMER STATES FACTORY MINIMUM 45,000 MILES SERVICE $149.00 ~ ~45K MILES SERVICE MAINT. ~ ~PERFORMED 45,000 MILES SERVICE
DESCRIPTION: REPLACED FRONT BRAKE PADS AND ANTI SQUEAL SHIM KITS ~ ~CUSTOMER STATES REPLACE FRONT BRAKE PADS AND ANTI SQUEAL SHIM KITS ~ ~FRONT BRAKE PADS WORN ~ ~REPLACED FRONT BRAKE PADS AND ANTI SQUEAL SHIM KITS
43283 MILES
REPAIR# 0082029
SERVICE: NONE AT THIS TIME
DESCRIPTION: NONE AT THIS TIME ~ ~DECLINED WORK DISCLAIMER ~ ~WORN TIRES ~ ~NONE AT THIS TIME
SERVICE: PERFORMED 40,000 MILES SERVICE, RESET MAINT. LIGHT., FB 8(MM), RB 5(MM), TIRE
DESCRIPTION: PERFORMED 40,000 MILES SERVICE, RESET MAINT. LIGHT., FB 8(MM), RB 5(MM), TIRE ~ ~CUSTOMER STATES FACTORY MINIMUM 40,000 MILES SERVICE $239.00 ~ ~40,000 MILES SERVICE ~ ~PERFORMED 40,000 MILES SERVICE, RESET MAINT. LIGHT., FB 8(MM), RB 5(MM), TIRE TREAD 5/32.,
SERVICE: MOUNT AND BALANCE FOUR NEW TIRES DESCRIPTION: MOUNT AND BALANCE FOUR NEW TIRES
~ ~CUSTOMER STATES REPLACE 4 TIRES DUNLOP GR TOURING ~ ~TIRES WORN ~ ~MOUNT AND BALANCE FOUR NEW TIRES
SERVICE: PERFORMED WHEEL ALIGNMENT DESCRIPTION: PERFORMED WHEEL ALIGNMENT
~ ~CUSTOMER STATES WHEEL ALIGNMENT 99.00 WITH 4 TIRE ~ ~ALIGNMENT ~ ~PERFORMED WHEEL ALIGNMENT
SERVICE: REMOVE STEERING SHIELD AND LUBRICATE SHAFT AND COVER BOOT
DESCRIPTION: REMOVE STEERING SHIELD AND LUBRICATE SHAFT AND COVER BOOT ~ ~CUSTOMER STATES THERE IS A WHINING TYPE NOISE FROM STEERING WHEEL WHEN TURNING RIGHT/LEFT, CHECK AND ADVISE ~ ~LACK OF LUBRICANT BETWEEN STEERING INTERMEDIATE SHAFT AND STEERING SHIELD ~ ~REMOVE STEERING SHIELD AND LUBRICATE SHAFT AND COVER BOOT
SERVICE: REPLACED LEFT REAR DOOR LOCK ACTUATOR ASSEMBLY
DESCRIPTION: REPLACED LEFT REAR DOOR LOCK ACTUATOR ASSEMBLY ~ ~CUSTOMER STATES LEFT REAR DOOR LOCK IS INOP WITH REMOTE, CHECK AND ADVISE ~ ~LEFT REAR DOOR LOCK ACTUATOR SHORTED ~ ~REPLACED LEFT REAR DOOR LOCK ACTUATOR ASSEMBLY
DATE: 07/03/2014
~ ~CUSTOMER STATES PERFORM MAINTENANCE INSPECTION ~ ~INSPECTION ~ ~PERFORM MAINTENANCE INSPECTION
SERVICE: PERFORMED L-SB-0013-13, R&R RIGHT REAR SHOCK DESCRIPTION: PERFORMED L-SB-0013-13, R&R RIGHT REAR
SHOCK ~ ~UPON INSPECTION FOUND RIGHT REAR SHOCK LEAKING FLUID ~ ~RIGHT REAR SHOCK INNER SEAL WEAKENED LEAKING FLUID ~ ~PERFORMED L-SB-0013-13, R&R RIGHT REAR SHOCK
https://secure.drivers.lexus.com/lex...bel=rx&print=Y 6/10
6/8/2017
LEXUS DRIVERS
35411 MILES
REPAIR# 0071533
SERVICE: COMPLETED FACTORY MINIMUM 30,000 MILE SERVICE.
DESCRIPTION: COMPLETED FACTORY MINIMUM 30,000 MILE SERVICE. ~ ~CUSTOMER STATES FACTORY MINIMUM 30,000 MILE SERVICE $580.00 ~ ~CUSTOMER STATES FACTORY MINIMUM 30,000 MILE SERVICE. ~ ~COMPLETED FACTORY MINIMUM 30,000 MILE SERVICE.
DESCRIPTION: PROVIDED LEXUS LOANER VEHICLE-95.00 DOLLAR PER DAY VALUE ~ ~CUSTOMER STATES PROVIDED LEXUS LOANER VEHICLE ~ ~LOANER REQUESTED. ~ ~PROVIDED LEXUS LOANER VEHICLE-95.00 DOLLAR PER DAY VALUE
SERVICE: REPLACED DRIVER'S VANITY MIRROR BULB DESCRIPTION: REPLACED DRIVER'S VANITY MIRROR BULB
~ ~CUSTOMER STATES DRIVER'S SUN VISOR LIGHT IS INOP, CHECK AND ADVISE ~ ~OPEN CIRCUIT OF DRIVER'S/LH MIRROR BULB. ~ ~REPLACED DRIVER'S VANITY MIRROR BULB
30660 MILES
REPAIR# 0064038
SERVICE: TEST AND REPLACED BATTERY. DESCRIPTION: TEST AND REPLACED BATTERY.
~ ~CUSTOMER STATES DEAD BATTERY, CHECK AND ADVISE ~ ~BATTERY FAILED PERFORMANCE TEST, BAD CELL. WARRANTY CODE 603P ~ ~TEST AND REPLACED BATTERY.
24737 MILES
REPAIR# 0054033
SERVICE: FUEL
DESCRIPTION: FUEL ~ ~CUSTOMER STATES LOANER CAR $9.00 FUEL USAGE FEE ~ ~FUEL ~ ~FUEL
DATE: 02/15/2014
SERVICE: PERFORM MAINTENANCE INSPECTION. DESCRIPTION: PERFORM MAINTENANCE INSPECTION.
~ ~CUSTOMER STATES PERFORM MAINTENANCE INSPECTION ~ ~PERFORM MAINTENANCE INSPECTION. ~ ~PERFORM MAINTENANCE INSPECTION.
SERVICE: RECOMMEND TO REPLACE FRONT BRAKE PADS, SHIMS, AND RESURFACE ROTORS.
DESCRIPTION: RECOMMEND TO REPLACE FRONT BRAKE PADS, SHIMS, AND RESURFACE ROTORS. ~ ~CUSTOMER STATES CHECK THE BRAKES AND ADVISE ~ ~BRAKE PADS LININGS MEASURE AT 3.5MM FR/7MM RR. ~ ~RECOMMEND TO REPLACE FRONT BRAKE PADS, SHIMS, AND RESURFACE ROTORS.
DESCRIPTION: REPLACED FRONT BRAKE PADS AND ANTI SQUEAL SHIM KITS ~ ~CUSTOMER STATES REPLACE FRONT BRAKE PADS AND ANTI SQUEAL SHIM KITS ~ ~FRONT BRAKE PAD WORN TO 3.5MM ~ ~REPLACED FRONT BRAKE PADS AND ANTI SQUEAL SHIM KITS
DATE: 11/04/2013
SERVICE: PERFORMED 25,000 MILE SERVICE. DESCRIPTION: PERFORMED 25,000 MILE SERVICE.
~ ~CUSTOMER STATES FACTORY MINIMUM 25,000 MILE SERVICE $79.00 ~ ~25K MILES SERVICE ~ ~PERFORMED 25,000 MILE SERVICE.
DATE: 06/25/2013
SERVICE: INSPECTED STEERING COMPONENTS., APPLIED ADDITIONAL LUBRICATION ON LOWER STEERI DESCRIPTION: INSPECTED STEERING COMPONENTS., APPLIED ADDITIONAL LUBRICATION ON LOWER STEERI ~ ~CUSTOMER STATES STEERING WHEEL MAKING WHINING NOISE WHEN TURNING RIGHT /LEFT, CHECK AND ADVISE ~ ~CHECK FOR NOISE WHEN TURN RIGHT OR LEFT.
https://secure.drivers.lexus.com/lex...bel=rx&print=Y 7/10
SERVICE: INSTALLED NEW ALL FRONT BRAKE PADS, TESTED
DESCRIPTION: INSTALLED NEW ALL FRONT BRAKE PADS,
TESTED ~ ~DURING INSPECTION FOUND LEFT FRONT OUTER BRAKE PAD IS WORN ~ ~LEFT FRONT OUTER PAD EXCESSIVE WORN ~ ~INSTALLED NEW ALL FRONT BRAKE PADS, TESTED
SERVICE: PERFORMED MACHINE RH AND LH FRONT ROTORS, TESTED
DESCRIPTION: PERFORMED MACHINE RH AND LH FRONT ROTORS, TESTED ~ ~DURING INSPECTION FOUND FRONT ROTORS GROOVED ~ ~FRONT ROTORS SCARRED ~ ~PERFORMED MACHINE RH AND LH FRONT ROTORS, TESTED
SERVICE: REPLACED REAR BRAKE PADS AND ANTI SQUEAL SHIM KITS, MACHINED ROTORS, ROAD TEST
DESCRIPTION: REPLACED REAR BRAKE PADS AND ANTI SQUEAL SHIM KITS, MACHINED ROTORS, ROAD TEST ~ ~CUSTOMER STATES REPLACE REAR BRAKE PADS AND ANTI SQUEAL SHIM KITS ~ ~REAR BRAKE PADS 3(MM) ~ ~REPLACED REAR BRAKE PADS AND ANTI SQUEAL SHIM KITS, MACHINED ROTORS, ROAD TESTED
19035 MILES
REPAIR# 0046854
SERVICE: R&R STEERING COLUMN ASSEMBLY, CLEANED AND LUBED TILT SHAFT, TESTED
DESCRIPTION: R&R STEERING COLUMN ASSEMBLY, CLEANED AND LUBED TILT SHAFT, TESTED ~ ~CUSTOMER STATES STEERING WHEEL IS MAKING A GRINDING NOISE AS IT IS COMING OUT WHEN STARTING THE CAR, CHECK AND ADVISE ~ ~STEERING COLUMN TILT SHAFT SEZING- MAKES NOISE ~ ~R&R STEERING COLUMN ASSEMBLY, CLEANED AND LUBED TILT SHAFT, TESTED
15672 MILES
REPAIR# 0042692
SERVICE: NO RECOMMENDATION AT THIS TIME DESCRIPTION: NO RECOMMENDATION AT THIS TIME
~ ~CUSTOMER STATES THERE IS A WIRE BURN SMELL WHEN HEATER WAS ON, CHECK AND ADVISE ~ ~CHECK VEHICLE FOR BURN SMELL, ROAD TESTED , NORMAL CONDITION ~ ~NO RECOMMENDATION AT THIS TIME
~ ~INSPECTED STEERING COMPONENTS., APPLIED ADDITIONAL LUBRICATION ON LOWER STEERING BOOT., TESTED
SERVICE: INSTALLED NEW LEFT FRONT DSC BRK CALIPER ASSY 1-SD, TESTED
DESCRIPTION: INSTALLED NEW LEFT FRONT DSC BRK CALIPER ASSY 1-SD, TESTED ~ ~LEFT FRONT BRAKE CALIPER IS SEIZING ~ ~LEFT FRONT CALIPER SEIZING ~ ~INSTALLED NEW LEFT FRONT DSC BRK CALIPER ASSY 1-SD, TESTED
SERVICE: PERFORMED FACTORY MINIMUM - 20,000 MILES SERVICE, RESET MAINT. LIGHT., FB 3(MM
DESCRIPTION: PERFORMED FACTORY MINIMUM - 20,000 MILES SERVICE, RESET MAINT. LIGHT., FB 3(MM ~ ~CUSTOMER STATES FACTORY MINIMUM - 20,000 MILES SERVICE $239.00 ~ ~20,000 MILE SERVICE ~ ~PERFORMED FACTORY MINIMUM - 20,000 MILES SERVICE, RESET MAINT. LIGHT., FB 3(MM), RB 3(MM), TIRE TREAD 7/32.,
DATE: 01/14/2013
DATE: 03/13/2013
https://secure.drivers.lexus.com/lex...bel=rx&print=Y 8/10
6/8/2017
LEXUS DRIVERS
SERVICE: PRICED PARTS AND LABOR.
DESCRIPTION: PRICED PARTS AND LABOR. ~ ~CUSTOMER
STATES BRAKES MAKING SQUEAK NOISE WHEN BRAKING UP, CHECK AND ADVISE ~ ~FRONT BRAKE PADS LOW 3(MM) OR LESS ~ ~PRICED PARTS AND LABOR.
SERVICE: REPLACED FRONT BRAKE PADS AND ANTI SQUEAL SHIM KITS, MACHINED ROTORS, ROAD TES
DESCRIPTION: REPLACED FRONT BRAKE PADS AND ANTI SQUEAL SHIM KITS, MACHINED ROTORS, ROAD TES ~ ~CUSTOMER STATES REPLACE REAR BRAKE PADS AND ANTI SQUEAL SHIM KITS ~ ~FRONT BRAKE PADS 3(MM) LEFT ~ ~REPLACED FRONT BRAKE PADS AND ANTI SQUEAL SHIM KITS, MACHINED ROTORS, ROAD TESTED
15672 MILES
REPAIR# 0042692
SERVICE: PERFORMED 5,000 MILE LIGHT SERVICE, RESET MAINT. LIGHT., FB 3(MM), RB 5(MM), T
DESCRIPTION: PERFORMED 5,000 MILE LIGHT SERVICE, RESET MAINT. LIGHT., FB 3(MM), RB 5(MM), T ~ ~CUSTOMER STATES 5,000 MILE LIGHT SERVICE ~ ~5,000 MILE SERVICE ~ ~PERFORMED 5,000 MILE LIGHT SERVICE, RESET MAINT. LIGHT., FB 3(MM), RB 5(MM), TIRE TREAD 7/32.,
10399 MILES
15 MILES
DATE: 03/15/2012
REPAIR# 0035819
SERVICE: 10,000 MILE FULL SERVICE
DESCRIPTION: 10,000 MILE FULL SERVICE ~ ~CUSTOMER
STATES 10,000 MILE FULL SERVICE ~ ~10K SERVICE IS DUE ~ ~10,000 MILE FULL SERVICE
https://secure.drivers.lexus.com/lex...bel=rx&print=Y 9/10
DATE: 01/11/2013
DATE: 10/05/2012
REPAIR# 0020883
SERVICE: PERFORM PRE-DELIVERY SERVICE & INSPECTION.
DESCRIPTION: PERFORM PRE-DELIVERY SERVICE &
INSPECTION. ~ ~CUSTOMER STATES PERFORM PRE-DELIVERY SERVICE & INSPECTION. ~ ~CUSTOMER STATES PERFORM PRE- DELIVERY SERVICE & INSPECTION. ~ ~PERFORM PRE- DELIVERY SERVICE & INSPECTION.
TERMS AND CONDITIONS
INFORMATION ACCURACY
Information presented on this website is summarized and standardized from repair orders completed at the time of service and submitted by Lexus dealers. When reviewing a vehicle?s service history, please note that all information is provided by the Lexus Dealer that conducted the service, and that dealer is solely responsible for the accuracy, completeness or authenticity of any information contained in this site. Lexus provides this site and all information and materials contained herein ?as is? without warranty of any kind. Any questions or concerns regarding this information should be addressed to the applicable Lexus dealer.
L/CERTIFIED OWNER INFORMATION
Dealer-reported service history records are linked to a vehicle's Vehicle Identification Number (VIN). All owner-reported service history records will be made available to the person who input the information on the site, but will not be shared with future owners of the vehicle.
OWNER*REPORTED INFORMATION AND PRIVACY TERMS
Lexus makes every effort to ensure the secure collection and transmission of sensitive user information using industry-accepted data collection and encryption methodologies. The information you provide is used by Lexus and its vendors and dealers to help improve the services we render. It is occasionally provided to Lexus dealers for their marketing use. Lexus will never sell your personally identifiable information to any other company. To learn more about our privacy policies and practices with respect to this website, please click here (//www.lexus.com/privacy/online-statement).
https://secure.drivers.lexus.com/lex...bel=rx&print=Y 10/10
6/8/2017
LEXUS DRIVERS
RX
SERVICE HISTORY
96376 MILES
REPAIR# 0056929
92477 MILES
REPAIR# 0050467
89329 MILES
REPAIR# 0046109
DATE: 03/02/2017
DATE: 12/10/2016
DATE: 10/13/2016
6/8/2017
LEXUS DRIVERS
88942 MILES
REPAIR# 0044709
83581 MILES
REPAIR# 0037291
81188 MILES
REPAIR# 0033860
SERVICE: NONE
DATE: 10/05/2016
DATE: 06/27/2016
DATE: 05/18/2016
74244 MILES
REPAIR# 0027406
DATE: 02/18/2016
67390 MILES
DATE: 11/12/2015
REPAIR# 0020220
63208 MILES
REPAIR# 0015398
59645 MILES
REPAIR# 0009479
DATE: 09/10/2015
DATE: 07/01/2015
56320 MILES
REPAIR# 0003865
52988 MILES
REPAIR# 0097906
SERVICE: NOTED
49437 MILES
REPAIR# 0091139
DATE: 04/17/2015
DATE: 01/30/2015
DATE: 11/04/2014
6/8/2017
LEXUS DRIVERS
SERVICE: NOTED
43283 MILES
REPAIR# 0082029
DATE: 07/03/2014
6/8/2017
LEXUS DRIVERS
35411 MILES
REPAIR# 0071533
30660 MILES
REPAIR# 0064038
24737 MILES
REPAIR# 0054033
SERVICE: FUEL
DATE: 02/15/2014
DATE: 11/04/2013
DATE: 06/25/2013
19035 MILES
REPAIR# 0046854
15672 MILES
REPAIR# 0042692
DATE: 01/14/2013
DATE: 03/13/2013
6/8/2017
LEXUS DRIVERS
15672 MILES
REPAIR# 0042692
10399 MILES
15 MILES
DATE: 03/15/2012
REPAIR# 0035819
DATE: 01/11/2013
DATE: 10/05/2012
REPAIR# 0020883
This driver must have driven with left foot on brake pedal the whole time. The front pads were replaced for the first time at 10,000 miles and have been replaced 5 times in 98,000 miles. Should have been replaced once or twice. There is a lot going on for just 98,000 miles. Run don't walk!!!
calisnoopy
10-25-07 09:26 AM
