whining noise
I have a 2015 RX350. I am hearing a slight whining noise from transmission or power steering when accelerating from a stop. You can only her it with the windows down and radio off. Is this a normal sound of RX350. Transmission and power steering is full.
You have electric power steering. How did you check that it was full? There is no fluid to check.
To check if transmission is full requires a complicated temperature flow test that really only a dealer can do. There is no dipstick.
However, the noise is probably normal.
