F-sport wheel question
Hi, so I put a set of the dark grey 19" RX F-sport wheels on my wife's 2nd gen but they did not come with center caps. The stock center caps from the 400h don't fit so I was wondering if someone had a picture and part number for the correct center caps. I'm not even sure what they're supposed to look like.
Thanks
Thanks
Try eBay. You can get good deals on either OEM or knock off's. Personally I would go for whichever is cheaper and good looking since it's just a cosmetic cap anyways. Not a "structure support" thing.
Another option is to call around junkyards in your area.
Thanks
Thanks
Try this SUPPOSEDly OEM BRAND NEW for $30 for a set of 4
http://m.ebay.com/itm/272712177631?_mwBanner=1
Or knock off's for $15 for a set of 4
http://m.ebay.com/itm/172717908131?_mwBanner=1
Or USED FROM AN OLD LEXUS (OEM) FOR $18 for a set of 4
http://m.ebay.com/itm/253027953148?_mwBanner=1
Or from one of the CL vendors (this is confirmed OEM). From $20 EACH !!! and up depending on color and finish as even OEM has different colors!!!
www.mylparts.com/oem-parts/lexus-center-cap-4260350300/?c=Zz1mcm9udC1zdXNwZW5zaW9uJnM9d2hlZWxzJmk9ODkxNDI1NTUmcj03JmE9bGV4dXMmbz1yeDM1MCZ5PTIwMTMmdD1mLXNwb3J0JmU9My01bC12Ni1nYXM%3D
Considering price differential, I would just get a set of 4 knock off's from a high volume excellent rated eBay seller. They usually just work with you to replace it if you have problems down the road as they want to keep their 99%+ rating.
Thanks for the help. Those look like stock wheel center caps, is that what the F-sport use? Also, in the second link, those are the ones I have now and they don't fit.
I'm not worried about oe or aftermarket, just want the correct ones.
