Exhaust heat shield loose and rattling
Galvanic corrosion, is what you describe...
Using Aluminium faster would't solve this, the crew would rust at the contact with the steel hanger..
The non metallic isolation is a better solution...
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
What exactly do you mean by technical doc? And most important is which heat shield. "Heat shield" is a generic term, and you have to narrow it down to where the shield is located. Technical document is typically published by a manufacturer for the supplier to provide/bid for the item. This document can be specific [particular to a certain heat shed] or even general where each shield must conform to. That document [if it exists] will not be in public domain.
Do you need the part number?
Call the Lexus parts in your area and give then the vin number. You can further help by guiding the discussion to proper assembly "exhaust system" [my best guess] and then work your way from the engine side back. If you are physically present at the sales counter, the parts sales person will flip the screen to you to identify the part you need. My experience is that the fasteners are listed there as well. [You don't start the search from fastener and try to work your way to the part you need].
Salim
Salim
https://www.lexuspartsoutlet.com/oem...MtNWwtdjYtZ2Fz
I was looking for the heat shield over the muffler for the vapor canister..
Indeed, if the screw housing isn't also aluminum, it would corrode there. I feel like @Clutchless solved it with epoxy, as did my mechanic. I think that's it.
I am looking for pretty much this
Except, the technician at the dealership called it an "exhaust heat shield" in the report. No parts number I'm afraid, but that might narrow it down a little bit for you when you contact your local dealership.
