CD player ejects
2010 RX350 --- "CD player ejects" while listening to SAT radio or when listening to music on iPhone connected via bluetooth
1) when hitting small bump on road;
2) when touching frame around audio controls- believed to be caused by static electricity from fingers.
Just started within the past 2 weeks
You probably will no longer be able to use the CD player unless you get it replaced which will probably cost more than you want to spend. Just take your CDs, burn them to MP3s, load onto a flash drive and play them through the USB connection buried inside the center console. You can load a huge number onto a 16 or 32 USB.
Do not put folders within folders as the system cannot read them. Just one folder per artist or CD then load the songs within it.
