Another 60k Recommended Service thread (dont shoot me)
![Wink](https://www.clublexus.com/forums/images/icons/icon12.gif)
I just took the wife's RX for a 60k oil change (I did the filters and brake fluid change). The dealer recommends a "TOP ENGINE CLEANING". What exactly does this entails? Is this a fuel injector cleaning? If so I can DIY instead of dropping $130.
Also it was advised to have a front wheel alignment done, which is definitely needed.
Maybe. Their cost is average for a dealer. See if it includes throttle body cleaning and gas tank additive.
The procedure cleans the carbon and deposits out of the intake system and engine top end, such as intake valves and piston tops. Usually they introduce a cleaning product through a vacuum line near the throttle body or sometimes through a fuel line to flow a concentrated cleaning mix into the engine for 15 to 30 minutes and dissolve the deposits. Usually they also will put some fuel system cleaner in the gas tank and maybe spray clean the throttle body. You can buy a kit to do it at home, but the cost is about half of what the dealer is charging. Many argue about the benefits of these procedures and some claim they just provide big profit to the dealer. However I have felt that cars with over 50,000 miles do benefit from it as they all seem to have deposits which can cause rougher idle, harder starting and worse mileage. On my cars they seem to be smoother and start easier afterward.
Deposit build up is a especially a big issue for direct injection cars (not the RX) which do not get any intake valve cleaning from the fuel as none flows over the intake valves.
I have my own fuel induction machine but got it years ago after having it done at my local repair shop. I found the exact one they used which looked like a hospital IV drip with a bleed valve to control the air and liquid flow rate. It goes in through a vacuum line.
vlad_a (11-30-17)
I'm not one to recommend extra service not included in the manual BUT my gen 1 had issues with dirty throttle body after 100K miles. So, I did the throttle body cleaning at around 120K miles and another one at 240K miles. YMMV.
Internal. https://westautomotivegroup.com/fuel...p-gas-mileage/
Usually only of benefit at higher mileage if you notice a drop in performance. As the link states, many dealers oversell it to increase profits.
For the notorious “dry start’ noise, characteristic of my 450h , I have been using the Liqui Moly product “2009 Anti-friction treatment”. I wanted to first test the product before revealing my results. The start noise appears to have disappeared.
I also purchased and will be using the following products:
LM Jectron gasoline fuel injection cleaner
LM 2037 Pro-line Engine Flush
LM 2208 0w-20 Special Tec Motor Oil, Synthetic
Eventually I willl be switching from Mobil One Synthetic to Liqu Moly with in the next 2000 miles.
Note: I am not compensated by Liqui Moly and sugggest you research these products on your own with others products before trying.
After 60,000 miles I came across a product line that may be of interest to you. Since I also have an Audi 2.0 TFSI and Volkswagen 1.8T, I need special 502, 505 oil and I have been researching the Liqui Moly brand of products.
do you have data on mpg improvement or oil analysis after using liquimoly? Or perhaps something like a dyno test on youtube?
I you want to research LiquiMoly and maybe find some VOA or UOA reports, visit www.bobistheoilguy.com and visit the European oil forum and the forums on oil analysis. That is where the petroleum engineers, gearheads and obsessive maintenance types hang out. I have been a member for years.
With some searching I am sure you will find many opinions and maybe some data.
Cocal (12-01-17)
is250fsprt
05-16-14 07:32 AM
