headlight upgrade
Old 12-16-17, 10:00 AM
lexusrus
lexusrus's Avatar
My 2013 RX450h has the HID low beams. But the fogs were halogens.
I changed the fogs to LEDs. I had a hard time matching with the same color as the HID low beams and the DRL's. At the end I just went with aftermarket $69 per pair 6000K LEDs found on Amazon. Three years later, they are still running strong!!! I did the same for my LX570 which had HIDs in the low beam, but halogens with the fogs. On my CT200h, none were HID as all were halogens. I changed the low beams and fogs to LEDs and left the high beams halogens.
Get the FANLESS LEDs. See my prior posts on the LEDs.
Originally Posted by Clutchless
The stock HID lights are not 5000K, more like 4300K. Depending on your model year, most of the HID lights turn when you turn the steering wheel a certain amount. This is one of my favorite features. I think they may have stopped it in 2013 or so.
Old 06-13-22, 12:38 PM
MellonC00
MellonC00's Avatar
following this dialog, I replaced my halogen bulb with HID replacements from Xenon depot. It's been about 90K miles since installation and I see that the light intensity is beginning to dwindle just a tiny bit. Do you think that is about normal?
Old 06-13-22, 04:20 PM
Clutchless
Clutchless's Avatar
Received 1,175 Likes on 1,003 Posts
Yes, they fade over time. Even the factory HID bulbs which are D4S should be replaced after several years, or that many miles as they gradually lose brightness.
Old 06-13-22, 07:28 PM
DallasLex
DallasLex's Avatar
So far I’m very pleased with these: https://www.audew.com/Audew-H11-H8-H...caArdDEALw_wcB
they’ve been installed since January. Will report back on longevity.
crenfro
SC- 1st Gen (1992-2000)
11-01-12 09:11 PM
harshybar
08-20-12 06:35 AM
lriver100
07-08-10 09:05 AM
STDave
10-29-07 06:38 AM
mikevanle
11-17-06 06:05 PM
Quick Reply: headlight upgrade
