My windshield wiper blades freeze up.
Lexus 2010 RX450H
How can we get the windshield wiper blades from freezing with ice and snow in a storm ? This has been the one disappointment with this vehicle. It is dangerous as it prohibits the wipers from working properly to clear the windshield while driving. Please help
Hearing from a Texan ...
raise the wipers away from the glass (wash) position before parking.
Stick newspaper [if you get one and recycle or just keep some craft paper or painters-paper] underneath the wiper blades.
Salim
Add-on:
Just realized the issue is WHILE DRIVING in Snow.
Salim
Add-on:
Usually the front windshield defrost feature works wonders. But may take a little while to kick in.
If you are already going, then the engine should be warmed up and ready to go.
Also I think the front windshield is "electrified" with electrical heating elements at the bottom and gets instantly warm once you hit the button to turn it on (but if it's frozen then it may still take a while to melt the ice). So I think if there is any concerns with this while driving, then it's best to leave the front windshield defrost feature turned on.
Lexus 2010 RX450H
Put one of the windshield rain repellent coatings on and the wipers will be less likely to stick, plus you will see better in the rain & snow. Several brands are available such as Rain-X, Aquapell, Enduroshield, Rainbrella etc
Available at any auto parts store or Wal-Mart.
Put it on all the windows and they will be much easier to scrape.
Lexus 2010 RX450H
Have to ask, what were you driving before and did it not have the same problem? Every winter car I've had in the last 30 years has had the problem, although winter wiper blades do help a little.
I tend to agree that if the snow storm is that bad, stay put.
Unless you are in emergency rescue team or something similar, I would stay put at home until it all clears up.
If you mean the build up on the left side and bottom of the windshield as you drive in a storm, all I've figured out over the years is to pull over and clear it off or stay at home and don't drive in a snow storm
I doubt that the wiper de-icer was available on the gen 3 RX sold in the U.S. since it was not mentioned in the U.S. gen 3 RX sales brochure. It is, however, shown as being standard in the sales brochures for the gen 3 RX sold in Canada.
The windshield wiper de-icer is not standard on the U.S. market gen 4 (2016-up) RX either but at least it is included in the optional "Cold Weather Package" like it also is for the current U.S. market GS and LS. The de-icer is standard on the Canadian market GS and LS.
I've never understood why Toyota can't put a windshield wiper de-icer heating element on all vehicles it makes for sale in the U.S. They are pretty darned simple, very effective and can't cost much to add - see the attached photo.
That's interesting.
I'll have to check on my RX450h and other Lexi's.
I know for sure that my CT200h got this bc when I changed the windshield the VIN numbers called for such and there were ELECTRICAL connections at the bottom of the windshield.
Maybe the only way to verify whether a gen 3 RX has a wiper de-icer is to remove the wiper arms and the plastic cowl cover and check for the presence of a de-icer electrical cable at the bottom center of the windshield.
Here is a parts diagram for the 2015 U.S. market RX assembled in Canada which also references some Canada market features. The heated windshields are labeled "CANADA SPEC" but maybe that isn't conclusive.
quiggs (11-22-23)
I use GM "Optikleen" washer solvent. Mix 2/3 water to 1/3 Optikleen. Gives superior cold weather operation of wiper blades. I tested it the other day at 2 degrees F. (actual temp) Available at most GM parts departments. FYI, heated windshields were only available for RX's spec for Canada. (Standard equipment)
Best,
Tom
Best,
Tom
I use the purple Rain-X and it works great for Northern New Jersey Winters. There’s always so much salt on the parkway that you need to constantly spray the windshield so that you can see anyway. The de-icing fluid works great at keeping the wipers clear. My previous RX, and ES had the heated pad under the wipers but it was honestly kinda useless. I always warm up the car so the regular defroster heats up the glass anyway.
Yaff
12-14-09 04:34 PM
