What "gen" is the Nav system in a 2014 RX350?
Do you see the "info"
Previous posts showed you were down in Setup.
It can be a difference in our models that you dont see the 'info' and I do.
Salim
Salim
There is no screen that says INFO anywhere...
When I go to Software Update, on the General Screen, It starts with
Model: 11LHENNA-AZ01
Then it shows:
Nav xxx
Bluetooth xxx
Gracenote xxx
Map Version --- ---
All have numbers except Map Version which shows only dashes.
Then it shows:
Nav xxx
Bluetooth xxx
Gracenote xxx
Map Version --- ---
So here is step by step.
Push Menu button on the center console
2nd icon on mine reads Info/phone
Select that by mouse.
Salim
Salim
You are a Genius!
Our systems DO vary...but you led me to my answer!!!
When I press Menu, I get icons labeled Destination, Apps/Info, Setup, Radio, Audio, Climate. Phone and Traffic.
If I go to Apps/Info...I get to choose from Fuel Consumption, Lexus Insider, XM Fuel Prices, XM Sports, XM Stocks or XM Weather.
But, I noticed at the top...next to the Return (backspace) arrow there was a note that said Map Data...so I clicked it and PRESTO
It showed my map version as 21-17-17 (2017-06-1)
You helped me find my answer...no matter how hard Lexus worked to hide it from a logical discovery placement!
Thank You! Thank You!
I'm comfortable knowing I've received the Update I paid for...
You are welcome.
Salim
Salim
