Fuse for the cigarette lighter for RX450h location???
Anybody knows the fuse location for the cigarette lighter for 2013 RX450h ??? I checked all fuse boxes and can't find it. Please help.
Thanks
Thanks
I know that for the RX350 it is in the fuse box under the dash by the driver side. I tapped into it to add a second power outlet in the console. I think it is the one in the top right area. The inside of the box lid identifies the fuses as will your owners manual.
Thanks. I'll look again. But last week when I looked I don't see any "panels" on the driver's side near the door area.
You have look in the right place. To do this lay on the floor and look up under the dash to the left of the steering column (towards the door side), there is a small box about 2 inches wide and 8 inches long. You pull the cover off.
I had to look for it.
On the driver side under the steering wheel/dash board area. You have to move the driver seat ALL THE WAY BACK AND RECLINE THE SEAT ALL THE WAY BACK. Then get in under the dash/steering wheel with your body looking up and your back down......slide in there and look for a fuse box. You will see one listed as CIG something.....take this out and look at it......most likely burnt out. Just replace with same kind/type/rating. It's hard to get in there to access it. But doable.....
dustin2413
HS 250h Model (2010-2012)
02-07-15 01:32 PM
JohnnyCake
09-22-14 01:58 PM
