Headlights
Headlights
Hello guys. I bought rx450h and it has halogen is there any way to install HID headlights not only convert bulb but also change full halogen headlight to HID one.
Give it a serious thought as to why you want HID after the purchase. Is it for the appearance (looks cool), better vision at night. Better vision is a relative term and the easy retrofit comes at the cost of blinding on-coming drivers. You can opt for ultrabrights ... just make sure you do not go too far on the wattage side. Ultrabites do have a shorter life.
Note: Dont get me wrong .. HIDs provide better light, but there is nothing wrong with halogens. I would suggest HID if you get the housing with the right cut-off (leveling) and focus.
Salim
Thanks for answer. But i dont want to change only halogen to HID. I want to replace halogen Headlight to HID one. Not just bulbs but also full headlight. Is it possible?
If all the answers are "Yes" then dive right in and do it.
People I know have sometimes expressed shock and disbelief at the vehicle modification projects I've done but I've had lots of practice over 50+ years including almost completely disassembling vehicles during restoration and rebuilding engines. I'm not a "pro" but that hasn't stopped me. If you have the time, an attention to detail and the "*****", then you should be able to do it.
That said, I have seen only one forum thread where someone was totally successful in installing an OEM HID headlight system on a vehicle made by Toyota that came with halogen headlights. The guy that did that was an electrical engineer and the vehicle was a Toyota Sienna XLE. That project was perhaps easier due to the beam level control for OEM Sienna Limited HID headlights being a manual switch/dial on the dashboard instead of being automatic and controlled by sensors attached to the suspension which is usually the way it's done on Lexus brand vehicles.
If you are comfortable doing the kind of vehicle disassembly I did three weeks ago on the Toyota brand vehicle as shown in the attached photo, then jump right in and do your project. You will likely have to do similar front end disassembly for your RX450h OEM HID system installation. Like many of my car projects, this one involved fabrication of electrical harnesses and even having one component custom made by a guy in Australia.
I don't remember ever retrofitting an OEM vehicle component or system that I could have had if only I had bought a vehicle that had it factory installed. When we want a vehicle with OEM HID or LED headlights, that is what we buy. I don't try to add it later since it's never cost effective. The only features/components that I add to vehicles after the purchase are features that are not available in the U.S. market and virtually all of them are related to safety.
celimages
04-23-19 02:01 PM
thomasfx10
12-25-16 12:28 PM
villan
03-01-11 12:52 AM
