RX400h wheels on a RX450h?
Hi,
I've searched for the answer to this but can't seem to find one anywhere on the forums.
I had a 2009 UK spec RX400h. This came with 18 inch wheels. I purchased a spare set of 18 inch wheels which have winter tyres on them.
I recently traded in the RX400h for a 2010 UK spec RX450h. This comes with 19 inch wheels, although, I do know some of these vehicles came with 18 inch ones as standard.
My question is, can I do a straight swap of the 19 inch wheels and tyres for my 18 inch wheels (from my previous RX) and winter tyres, or will I need to purchase a new set of 19 inch wheels and new winter tyres?
I'm hoping it's a straight swap, but wanted to ask first. I see from a number of websites the 18 and 19 inche wheel dimensions are slightly different (eg offsets etc.)
Many thanks in advance
Guy
Guy
Your 19 inch wheel will stick out 3 mm (0.1'') farther. this is perfectly fine. but the new wheel set will fill out the wheelwell by extra 13 mm. You may or may not have enough room. but the bigger problem is that your speedometer will read 60mph (96.6km/h) when your actual speed will be 62.2mph (100.1km/h).
Here are some reference values: your 18 inch wheels have 38mm offset and your 19 inch wheels has 35mm offset. keeping this in mind go to this website and compare the wheel sizes and see how it fits.
https://rimsntires.com/specspro.jsp
That's really helpful thank you.
I'm not too concerned about the speedo being out as it's only a few mph.
Would you suggest the best thing to do is to actually try and fit the wheels and check for enough clearance around the tyres?
Once again, thank you for taking time to help me with this.
Guy
Guy
Guy
Guy
Ok, will do.
I was concerned about suspension travel and the tyre hitting the wheel arch.
I don't go off roading, but the roads in the UK are full of bumps and holes!
Appreciate all the help so far received. Thank you.
Guy
Guy
IMO, you can probably get away with it.
However if you were to look at the diameter difference, the current tires are 26 mm (3.6%) bigger. The tire shops here will not install anything more than +/-3%. You're just slightly above that 3% margin. I am not sure if there any local laws that would consider 3.6% unsafe and list you liable for any accidents.
Just my two cents, stay safe.
I just realized that I did this backwards (going from RX450 wheels to RX400). but instead, you are fitting an RX 400 wheels into RX450h. Sorry.
so the calculation is backwards.
Suspension clearance: the new wheel is 3 mm (0.1'') closer to suspension/brakes components. Acceptable for most cars.
Fenders clearance: 100% clear (leaves even more room than OEM)
Wheelwells clearance: 100% clear (leaves even more room than OEM)
SPEEDOMETER: When speedometer reads 60mph (96.6km/h) actual speed will be 57.9mph (93.2km/h): 3.5% slower.
It looks like this is do-able with no major issues then, MellonC00?
Thank you Kezgao for your comments too.
As you are all so expert on these issues is there a way that I could get within the 3% difference Kezgao mentions if I were to change the tyres from 235/55s to maybe 235/60 r18s perhaps
Or would that create other issues?
Also, just for my own curiosity really, when wheels are described as, for example,et35 7.5jj 114x5
i understand the 114x5 is the hole spacing and number to ensure they will fit to your hub. I think the et35 part is the offset, how much they stick out from the hub (so as to ensure they don't foul the brakes etc). But I don't understand the 7.5jj part. What do the letters mean?
I'm learning a lot about tyres and wheels today!
Right, off to shovel snow and wait for your responses.
Here's a link to a Tire Size Calculator, where you can figure out the differences yourself. Hope this helps.
https://www.tacomaworld.com/tirecalc...0r18-275-65r18
Marqevans
RX - 3rd Gen (2010-2015)
40
01-15-15 03:27 PM
