4th Gen 20 inch wheel on 3rd Gen
Hello all, I recently purchased a 14 RX350, I am curious to find out if the 20 inch mesh wheels from the 4th Gen RX will fit on our 3rd Gen.
Sorry if this was already ask, I tried searching the forum and didn’t see a discussion about it. Thank you
It should bolt right on as Lexus did not change the hub size, offset or bolt pattern as it is common to most of their vehicles. They made no major suspension changes in the next generation. You will need to select the correct plus one tire size to keep your speedometer and odometer readings accurate. According to Tire Rack you should need 235/55/20 tires.
If you want to save some money, I would look on eBay or here for used wheels as opposed to new ones. http://www.wheelcollision.com/store/...00H-RX450H.htm
GS1stgen
GS - 1st Gen (1993-1997)
05-02-07 05:57 PM
Ken'sGS300
Wheels, Tires & Brakes Forum
03-15-05 09:02 AM
