Towing Capacity for 2009 Mariah Boat
According to a boating forum, the estimated weight of a "dry" Bowrider and trailer is around 4,500 pounds which is far over the 3,500 rated towing capacity of your RX. https://www.winnipesaukee.com/forums...ad.php?t=13485
So ... my answer would be "No" unless you are going to tow it only few miles at slow spends and are going to launch it but not retrieve it - e.g. put it into the water for the season but have a commercial service pull it out of the water at the end of the season. This is what I did when I towed a 3,500 pound boat/trailer a few miles with a 4-cylinder Mercedes Diesel sedan; I launched and kept the boat in the water for the season and had a commercial service pull it out at the end of the season.
Assuming you are talking about a Mariah R19.9, the 3200 is just the weight of the empty boat. You have to add the weight of the trailer, around another 900 lbs. Then there is everything else in the boat, i.e. 40 gallons of gas will add another 240lbs,
Was looking at towing capacities between RX and NX, and RX is regularly quoted at 3500 lbs (per Lexus too). Should I ignore the following Google results? Was just wondering if RX tow capacity can really drop below NX spec based on equipment/options?
Don't have my manual in front of me, but I believe that is the tow rating for a RX without the towing package.
Thank you, tus! I always thought 3500 was standard and that I'd only need to slap on a tow hitch. Definitely new and good info for me to keep in mind if we get a used RX. Thanks again.
I'll check my manual when I get a chance.
trevor2003
GX - 1st Gen (2003-2009)
06-09-17 10:28 AM
