Window trouble
i just had body work to my car and I find the passenger side window cannot be controlled by the Master on the driver’s side. Went through resetting all of them and the others respond. Can open if from the passenger door itself. Any thoughts?
Return to the body shop and make them fix it correctly. You did not say which door had the work done. However if it worked before and now does not, then they failed to do a complete job. Everything is supposed to work like before when they are done with repairs.
Yep, if it worked prior to going into the workshop and not after it came out, then the workshop may have carried out repairs which somehow disabled the window function. They should get this issue sorted out for you.
Did they happen to work on the driver's door? I had a similar issue on a Camry after the door got munched. When I noticed the switch not working, a guy came out and within 3 minutes he had pulled the panel off, reseated the switched connector, and had it back together again, all working.
Archi
RX - 1st Gen (1999-2003)
04-18-18 01:26 AM
