Torque specs for a complete brake job
Can someone point me in the right direction to find the torque specs for a complete brake job? 2014 rx350 fsport. Replacing pads and rotors only. Will eventually get new calipers, but not now.
Thanks.
Thanks.
why do you need new calipers? These are the specs I use on the fronts, the rears i use the same torque spec on the bracket bolts.
these appear to be the same specs as 1st gen RX300
Application Ft. Lbs. (N.m)
Brakeline-To-Master Cylinder ......................... 11 (15)
Caliper Installation Bolts
ES300 & RX300
Front ........................................... 87 (118)
Rear ............................................. 25 (34)
GS300 & GS400
Front ............................................ 25 (34)
Rear ............................................ 77 (104)
LS400, SC300 & SC400
Front & Rear ..................................... 25 (34)
Flexhose-To-Brake Caliper Union Bolt ................. 22 (30)
Push Rod Lock Nut .................................... 18 (25)
Sliding Bushing Bolt ................................. 14 (19)
Torque Plate Bolts
ES300 & RX300
Front ........................................... 79 (107)
Rear ............................................. 34 (47)
GS300, GS400, LS400, SC300 & SC400
Wheel Lug Nuts ...................................... 76 (103)
INCH Lbs. (N.m)
Bleeder Screw
All Except ES300 & RX300 ........................... 96 (11)
ES300 & RX300 ....................................... 74 (8)
Booster Installation Bolts
All Except ES300, LS400 & RX300 ...................... 8(12)
ES300, LS400 & RX300 ................................ 9 (13)
Master Cylinder-To-Power Brake Unit Nuts .............. 9 (13)
Parking Brake Adjustment Lock Nut ..................... 48 (5)
Reservoir Set Screw
Except LS400 ........................................ 16 (2)
LS400 ............................................... 16 (2)
Stopper Bolt (Master Cylinder)
ES300, RX300, SC300 & SC400 ......................... 7 (10)
LS400 .............................................. 11 (15
ES300 & RX300
GS300 & GS400
Torque Plate Bolts
ES300 & RX300
INCH Lbs. (N.m)
Bleeder Screw
Reservoir Set Screw
make a weekend project out of it, start with the rears because you have to bleed them first and do the fronts on another day. Degrease , prep and paint. I use Dorman brake banjo plugs to minimize brake fluid leakage when pulling off my calipers Dorman part 13888 for 2 plugs @ $1.50 a pack.
