Power liftgate motor shot, need some DIY help
So it looks like the power lift gate motor on our 2013 RX350 is shot. For a few months, it was working intermittently, but now it completely stopped working. When pushing the close button, it only gives one long beep now and nothing happens. It also doesn't open automatically anymore either, but I can hear the trunk unlocking and relocking, so it’s not like it’s disabled from the glovebox switch.
So I was trying to see if I can pull out the motor and diagnose/order a replacement. Has anybody done this before, is this a DIY job?
I have tried to remove the rear headliner, but not sure if it can be removed without taking out the panels on the C pillar, which I don't know how to remove. I really don't want to rip or break it, so does anybody have any instructions on how to remove the headliner?
Thanks
Thanks
Shnewzhere (08-13-20)
Don’t think the struts are my issue. I can feel the motor engage a little bit, but it doesn’t move the trunk.
i am currently trying to troubleshoot this issue on my 2010. The trunk door will come withing 4 inches of the bottom when closing then stop , beep twice and reverse. I have to manually help the trunk along. One article i've come across suggested it is a problem with one or both of the sensors on either side of the trunk. Parts 84260G & 84260F . So far, lubricating the struts did not help.
Well, I think your problem may be different from mine, since mine doesn't move at all. But I had no clue that there are sensors there, so now I am not even sure anymore if it's really the motor that is bad. Wondering is a failure of these sensors could also cause the symptoms I have. Do you know where these sensors are located and what they do?
konradsa (05-19-18)
They are located left and right of the door as shown in the diagram. They are for "jam protection" as described in page 51 in our owners manual. After attempting to close my trunk door multiple times it didnt want to move at all, apparently it went into manual mode.. according to the owners manual. ..BUT i was able to attempt auto mode again after locking and unlocking the doors and pushing the trunk button inside. The trunk will still not close all the way and will come back up.
I greased up the struts too for good measure, maybe I will replace those, that seems to be a pretty cheap and easy thing to do and they may play a role in my issue somehow.
From the user manual
Here's a video of me replacing my liftgate actuator in my 2013 Lexus RX350.
https://www.youtube.com/watch?v=TirM...YOf4Rjp4AaABAg
This is awesome, thank you. Since ours also works intermittently, I was assuming there must be some sort of control board somewhere that has gone bad and and the itself motor is okay, but maybe there isn’t and they are both one unit. We have just learned to live with it for now, opening and closing the trunk manually. But would be good to get this fixed one day.
Where did you get the motor from and what was the cost? And can you report back after a bit whether any issues have returned? Thanks
2014 rx350 lift gate motor repair
I took the motor apart, cleaned commutator with 4000 sand paper and used electric cleaner for brushed. Gently used my compressor to blow away all dust. Worked perfectly.
i QUOTE=konradsa;10202859]
Thanks
[/QUOTE]So I was trying to see if I can pull out the motor and diagnose/order a replacement. Has anybody done this before, is this a DIY job?
Thanks
It has almost been 4 years and it is still working great. Not a single issue.
Also, that’s awesome that you got your motor to work, good to know that’s an option. Please let us know if the problem comes back in the coming months and hopefully years! Was it really dirty?
Hello. That is my original motor that I rebuilt.
once you remove the entire mechanism from the car it is really straight forward to remove motor cover as shown on the picture and clean brushes and commutator with electrical spray.
Clutchless (05-11-24)
