hatch back
Are you opening the hatch using the button on the key fob? With our 2015 RX350, you must press the button on the fob for at least three seconds before the hatch will begin to open. I assume this is a safety feature to keep the hatch from opening with just a momentary press of the fob button (such as reaching for the fob in your pocket and accidentally pressing that button while doing so).
My hypothesis is that the Key-fob released the hatch but it did not rise up as the motor quit due to imbalance. Now as the temperature during the day got higher the struts woke up and then the hatch opened up.
So test out by manually lifting the hatch early morning and see if the hatch is balanced. If it keeps dropping down then the struts need replacement.
Far stretch? Maybe!
Salim
When the struts fail, the gas pressure is not enough to balance the weight of the hatch. The lift motor has just enough force to move a balanced hatch. The gas pressure (when the strut fails) gets impacted by the ambient temperature. One notice the onset of fail during cold. With that as a background
Far stretch? Maybe!
Salim
Far stretch? Maybe!
Salim
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
rx350drivr
RX - 3rd Gen (2010-2015)
64
06-05-23 07:18 AM
