Replaced tires , TRAC off
Old 12-06-18, 08:29 AM
Airbalance
Airbalance's Avatar
Default Replaced tires , TRAC off
Had the tires replaced , on Tuesday , than noticed a note that TRAC OFF in the dash display , was there only for a short while
check the ECS (?) setting and snow setting was off, and could not toggle it on
there no light about tire pressure
could there be problem with the TMPS tire sensors ?
Old 12-06-18, 12:10 PM
RX in NC
RX in NC's Avatar
Are the new tires the exact same size as the old tires? In today's world when our vehicles are essentially rolling computers, some of them will light up the dashboard with various warnings if the replacement tires are a different size than the previous set. I would also check all tire pressures with a known-to-be accurate digital tire gauge. I never trust the on-board readings. My 2013 Subaru Outback 3.6R can have a tire more than 5 psi too low and the TPMS never even blinks an eye.
Old 12-06-18, 12:44 PM
Airbalance
Airbalance's Avatar
Same size
is there a separate button for traction control that maybe got turned off
Old 12-07-18, 08:20 AM
vlad_a
vlad_a's Avatar
Sounds like the trac off button got stuck or pushed accidentally. Any liquids spilled in the area recently?
Trac off button is behind cup holders, in front of the armrest. Press it once and traction control is disabled until you hit 25MPH. Hold it while stopped and it will be off until the next vehicle restart.
Old 12-07-18, 09:02 AM
Airbalance
Airbalance's Avatar
thanks
I will take a look next time I am the RX
had a hip replaced a couple of weeks ago so I am in the RX really just to go to Physiotherapy
Old 12-07-18, 03:32 PM
Airbalance
Airbalance's Avatar
Stupid me ,
move arm see TRAC button
ECN snow button , I though you used the < > buttons to switch it on, but you click on enter to switch on/off
daryll40
RX - 4th Gen (2016-2022)
46
04-07-22 06:19 AM
Reggie1
LX - 3rd Gen (2008-2021)
03-13-17 10:09 AM
Shaft350
03-06-08 05:33 AM
sweet
07-26-07 06:42 AM
Kyosuke86
01-07-06 03:37 AM
Quick Reply: Replaced tires , TRAC off
