Passenger side seat heater won't turn off
Hi all. I just picked up a 2012 RX450H FWD and the passenger side seat heater heats the seat even when the switch is set to off (the heater does turn off when the car is off). I replaced the switch and it still happens. I'm thinking it may be a relay that's gone bad, but I don't know where any of the seat heater relays are. Any thoughts/suggestions?
If you bought it from a dealer I would take it back. Otherwise you could pull the wires from under the seat as a temp fix. Check the owner's manual and the under hood relay box as it has a map under the cover and maybe it will help identify the relay you seek.
