Rubber strip came off
pam1980 (01-18-19)
I checked with the dealer and they said they don’t ‘fix’ this, they need to replace it and it was way more than $100 as they said should do both sides at the same time. I did try to tuck them back in but keep coming out and concerned about paint coming off.
After more ore searching here, found this
https://www.clublexus.com/forums/rx-...oming-out.html
Just a thought (and I could be completely wrong)
Many times when a part comes out, like yours, it is worn. it looks ok, but it is not. If you get a new piece it will go in and stay in as it should.
finally, if it is held in with and adhesive, but sure the surface is PERFECTLY clean before installing the new one. My favorites are acetone or ammonia and water and let it dry completely.
I would try contact cement. Strong enough to hold it in place as required, but weak enough to allow you to remove the strip (and the glue residue) if necessary down the road. As pointed out above, the area will need to be squeaky-clean and dry before you apply the glue.
shaitaan
SC- 1st Gen (1992-2000)
12-18-06 09:23 AM
