RX 350 oil catch can
I have a 2014 RX 350 with 50K miles running like new. I just did a clean with Gumout and wanted to install an oil catch can, thinking of keeping this car of a while. Can't find any posts to see where folks have mounted them. Are there no RX owners with OCC installed?
I don't think that is an issue with this vehicle as it is not direct injection. There is no history of abnormal valve carbon deposits that would warrant installing a catch can. Just run some Techron Fuel System cleaner a couple of times a year and maybe do a fuel induction cleaning service every few years or 50,000 miles if you have a lot of miles and your intake valves should be clean enough to run smooth.
You may want to check https://www.toyotanation.com/forum/8...ion-2001-2007/
as it has the same engine & transmission etc.
What kind of cleaning did you do with the Gumout? Pour it in the tank or drip through a vacuum line into the engine?
^^ What he said. Techron is a great product. It is the only fuel injection system cleaner additive that I am willing to spend money for. I wait for the BOGO sales at the big box stores like Advance Auto Parts or Pep Boys and then pick up several of the 20-ounce bottles for half-price. A bottle of Techron gets poured down the hatch at every oil & filter change on all of our vehicles.
Thanks for the info, I did not know it is not direct injection, so I won't be installing an oil catch can. The Gumout bottle has 16 oz. so I did 6 oz in the crankcase (where oil goes) since it is recommended 1 oz for quart of oil, then the 10oz left goes to the fuel tank. Gumout and Techron both have P.E.A cleaning agent which per my research works for modern cars.
Gsw1
Maintenance
08-20-18 04:09 PM
farcry80
12-17-10 11:55 AM
