RX 350 2010 Led Headlight Replacent
![](https://cimg3.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_20190614_212016_4e09795d9b229de32552c166a61bc07f7831a3da.jpg)
I bought LED replacements for my high beam but the connector doesn't fit the Xenon connector. There is a plug going into the ballast but I can't figure out how to find an adapter that will fit the plugs on LEDs I bought. Anyone have an idea?
Having ballast means that you have HID headlights. This is great perhaps the only thing you need to do is to replace them with higher intensity/higher kelvin count. Please check Amazon and you'll find great selection that really works better than LED. The original headlight low beam kelvin count is 2500 as far as I remember. Stick to 5000 Kelvin and you'll be amazed by the light intensity.
You could use your newly purchased LED lamps in your fogs or High beams. This is what I've done and I'm happy with the outcome.
Cheers ..
Cheers ..
