Good tire and wheel / rims combo for 2014 RX
Hello,
Proud owner of 2014 RX. Been thinking of swapping the OEM rims with bigger rims as the stock 18 inch rims is a bit smaller.
Looking to make it a bit nicer and also not sacrificing the comfort as well
anyone can recommend a good tire and rim combo for 19 or 20 inch?
Thank you
Thank you
Get 19x8 wheels so you can use 255/50/19 tires that are 20mm wider than stock. Be sure the new wheels are hub centric as you want to avoid having to use centering rings as they can cause problems. I recommend you look at www.tirerack.com as they have a large selection and good advice.
Also Lumarai makes excellent wheels that are hub centric and the correct offset https://www.lumaraiwheels.com/
Thanks.
Not common in OEM that would also fit the RX350. The Lexus IS-F from around 2011 give or take a few years has 19x8 wheels that fit perfectly as my wheels are copies of those. However I no longer see them for sale. You cannot just put Ford or BMW wheels on a Lexus. All the parts have to match, center ring, bolt spacing and offset. You are really limited to Toyota and Lexus OEM wheels. Aftermarket, anything is available.
