Looking to get an RX350, which year is recommended?
Old 08-02-19, 03:44 PM
cookie4u
cookie4u's Avatar
Originally Posted by RX in NC
But I have read that leaking rear shocks in the pre-2013 RX models were a problem. It seems to have been resolved by the 2013 model year.
No, I just purchased a 2013 with 76K and the shocks had leaked at some point and were trashed.
Old 08-03-19, 07:33 AM
RX in NC
RX in NC's Avatar
^^ Sorry to hear that. Looks like Lexus did not upgrade the rear shocks after all. Anyone know for sure?
Old 08-13-19, 01:45 PM
TBLAP187
TBLAP187's Avatar
Default 08 oil line
Just had the oil line go on mine at 193,000 miles. Had about half a quart left, no light, no warning. The car never ran weird or made any noise and still runs great after getting it fixed this week. Definitely an inconvenience for sure. Bought it with 189k and had the alternator go. About a $450 part plus labor. Other than that the car is awesome. Definitely will buy a newer one when I upgrade.
Old 08-13-19, 05:35 PM
ronmaiden
ronmaiden's Avatar
Originally Posted by riredale
(2) Dealer gave me a 2-year warranty, which was great, because they replaced the 12v battery ($250) and the rear lift struts ($200), and a biggie, the braking actuator that had begun making "barking seal" noises, a well-known and expensive issue with Lexus cars ($2,500). So the dealer warranty was very valuable to me.
Is the brake issue a common one and what was exactly what were the brakes doing? Barking seal noises when braking?
Old 08-21-19, 06:39 AM
Eponagirl
Eponagirl's Avatar
Ok, thoughts on what might be the better buy?
2013, well maintained according to Carfax, with 45 ish miles
OR
2015, well maintained according to Carfax with 85 miles
both around $23k
Old 08-21-19, 07:37 AM
RX in NC
RX in NC's Avatar
You need to use the VINs to research the full service history of both vehicles. Until you do, you are just guessing.
Track down the actual service providers, call them, and discuss exactly what they did. Carfax records are not specific enough. I always spend a day making phone calls and talking with the service providers before I make my final decision regarding whether or not to make an offer.
Old 08-21-19, 08:02 AM
Non
Non's Avatar
I always went for the older car with lower mileage. But the car must look like it was cared for. I can tell whether the car was always up kept, or if it was just detailed for sale.
Old 08-21-19, 08:33 AM
Notgrownup
Notgrownup's Avatar
You should be able to get a lower mileage 15 for that same price... I did... Just bought a 15 with 50000 miles. Well kept. Spoke to the previous owner. said he had all the service records and was really **** about it... He is going to get me the records but you can tell a lot by getting somebody to look at it that knows about them.
We love ours. After having it for 2 weeks , my wife drove it to Canada by herself then I flew to Buffalo and we drove it through NY, OH, KY, TN, VA and back home to NC,, Flawless.
Carfax only tells you what was reported. I like to talk to the previous owner if the records are not readily available. Can also be a crapshoot... lemons do exist everywhere...I make Margaritas with mine...
Old 08-21-19, 08:45 AM
Eponagirl
Eponagirl's Avatar
2013- regular maintenance intervals at this same dealer were done frequently. Only other things that were done over the lifetime: battery replaced (owner left trickle charger on while away for 6mo and blew the connection), refinished rear bumper and scratch repair, shocks replaced, water pump replaced, new tires.
Seems well maintained, unless any of those things are red flags? Looks like the dealer inspected as if CPO, it's not listed as CPO, maybe just missed the cutoff for CPO age requirements, was newly purchased in Sept 2012.
Thanks for your input and helping me out!
Old 08-21-19, 08:48 AM
Eponagirl
Eponagirl's Avatar
I got the service history on Lexus Owners site, not just Carfax. I know Carfax is iffy at times.
Old 08-23-19, 10:36 AM
Clutchless
Clutchless's Avatar
Received 1,193 Likes on 1,020 Posts
Eponagirl - none of those repairs are red flags. The rear shocks leaking were a well-known issue and some folks had water pump problems, but now you have a replaced water pump and fresh coolant. Although it is rare for one to fail with less than 45,000 miles. It was under warranty.
With that many miles I would think the brakes would have been done by now. What is their status?
Sounds like a nice vehicle. Did you get it?
Old 08-23-19, 11:22 AM
Eponagirl
Eponagirl's Avatar
Clutchless, thanks for the input. Brakes were declined by previous owner to be replaced (probably knew at that time he was going to sell/trade in). It appears that this car was only driven 6 mo out of the year. Must have gone down to FL for the winters (there was a service down done there at some point). Is it a problem to get a car that was put away for that long? It might have been driven a little by someone during the 6 mo away time. Explains the low miles. Also, is there much difference between 2013 and 2015? I was considering holding out for a good 2015, but if this sounds like a good car, then maybe I should just save the extra money and get the 2013?
EDITED TO ADD: the brakes were listed as Front 6mm and Rear 4mm remaining. Not sure if that is good or bad? Should I get the dealer to replace before buying?
Old 08-23-19, 02:08 PM
SilverRX30
SilverRX30's Avatar
Brakes at my dealership would require new pads when the thickness is at 3 mm or so.
6 mm and 4 mm .......looks like a rear brake pad replacement coming soon. Consider factoring the cost of new pads plus labor into your offer.
I purchased a CPO with 6 mm and 6 mm May 2018 and had my front pads replaced 1 year later.
Of course driving habits will factor in too.
You could also have an independent mechanic inspect the car prior to your purchase.
Good luck!
Old 08-23-19, 03:21 PM
Clutchless
Clutchless's Avatar
Your rear brakes need to be replaced. On the RX the rear brakes wear out first most of the time. Ask them to replace the front and rear brake pads as part of the deal. It will cost them very little vs what you would pay a shop later.
I don't know the differences between a 13 and a 15. I suspect it would be if anything, improvements to the infotainment system. 13 was the year of the mid model refresh from the 2010-2012 models.
Old 08-24-19, 06:48 AM
lex_rx
lex_rx's Avatar
And don't forget to ask them to upgrade the maps as part of the deal.
Quick Reply: Looking to get an RX350, which year is recommended?
