Navi screen auto sleep
Hi,
I cant seem to find my answer anywhere, is there a setting to turn the navi screen off over a period of time?
for example if I am on the 'climate' screen should the screen not turn off over a period of time? I understand if I was using navigation then it should stay on. On my Acura it auto turns off if not in use.
any insight?
any insight?
On my 2nd gen MY screen goes back to my energy screen(hybrid power distribution) after a set amount of time(seems like 20secs) unless i am using the nav screen regardless of using destinations. On my wife's 2011 the nav screen is always on as a default and comes back on after executing a specific command. ie radio/aux mode change, again, after a preset time . Neither of our screens ever go dark. Never ever.
No auto off. You can manually turn the screen off if you like. On some (earlier I think) models there is a DISP button on the left side of the remote touch assembly. Hitting this button takes you directly to the display settings screen where you can click "Off". On other models, you must access the Display settings through the menu button, but again have to click the "Off" option. The screen returns by pressing the DISP button (if equipped) or any other button if not.
Mine, a 2013 F-Sport with Navigation turns off on its own after about 60 seconds. I've set it up long ago to turn off the radio/mp3 screen so it won't distract me while driving.
If this is exactly what you're looking for, let me know and I'll go through the setup menu and send a few notes.
Cheers.
Cheers.
Cheers.
Cheers.
For example, I made some climate changes and about 5 minutes later it reverts me back to navigation.
What you need to do is once you set it to "On" and click "save", you need to turn the screen off manually.
Now, turn on media by hitting the "media" button so the screen turns on whether it's the radio or the USB .... and within a few seconds it will turn the screen off.
This will always be the case unless you use the navigation.
I guess it's putting the computer into a learning mode.
Let me know.
Thanks
I tried it and yes, it reverted me to Navigation.
Let me know.
Thanks
Let me know.
Thanks
