b2799 engine immobilizer system fault
I own 2011 RX350 Base model Canadian Made. few days ago the car dis not start so i try few times and then it start, i took it to the shop and the following code pop up b2799 they reprogram the Key Fob and the problem continue the car did not start always, after disconnecting the battery for long periods the car start, they recommended to order the Immobilizer part 625068-000 module for replacement to replace the part the dash complete need to be removed any suggestions. They have try to clear the code with the computer and not successful, the car start sometimes yes and sometimes not.
From what I read quickly it is more likely a key issue and a dealer may be your best bet for this repair. It could even be a Toyota dealer.
This is an engine immobilizer code, the computer does not recognize the key you are using. Make sure you are using the key that always started it before, any other non programmed key will not work, it has to be a key with a transponder chip and it has to be programmed to work with the computer.
https://www.toyotanation.com/threads...ilized.265709/
So if the problem is with the duplicated key only then the finger points to the key. Try the original to confirm that the original never gives you trouble.
I too would suggest the dealer as the current approach seems like throwing parts at the problem. The dealer may do the same thing, but I too believe in going to the "right" folks to get the issue resolved.
Salim
Salim
