2010 RX 350 No Driver Side Heat
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
I have a 2010 Lexus Rx 350 AWD made in Canada with 118K miles. I purchased it with 50K and it has been a trouble free 68K miles just minor maintenance items a new battery, tires and brakes. I just started having an issue with the heat not working on the drivers side only. I researched it online and watched a youtube video with a guy that had a similar problem but his drivers side was no a/c. To date i've done the following to fix it with no success:
1. Re-Charged my A/C. (Super cold a/c but no fix to the heat issue)
2. I replaced the drivers side air blend actuator and still no heat. (I purchased the cheaper version of the standard product from Rock Auto the part looked the same as the much more expensive one)
I'm still trying to figure it out with no success. I have heat on the passenger side and A/C. The drivers side is just A/C no matter what temperature you set the drivers side at. Please let me know if you have any idea on how to repair this issue?
Look at this prior thread, although it deals with A/C it is similar
https://www.clublexus.com/forums/hyb...-one-side.html
Also do you still have the original coolant or was it changed recently?
Hi Iolmaster!
Thank you for your help!
I had the radiator coolant flushed and replaced at 85K in December 2017. I have about 33K miles on the new coolant in just under 2 years.
The door actuator is replaced but following your link i was not aware of a air mix servo. I searched the part and found that the air mix servo was for an older model and doesn't fit my model year. The servo and actuator door look very similar. I felt relieved that someone on the thread said they replaced the servo twice on 250K Rx330 so it's more than likely the same issue i'm having.
I'm not sure what i'm missing but everything leads back to the actuator door. I may have a defective actuator door (Even Though It's Brand New) or I may have installed it incorrectly but something is still amiss. I'm going to double check the install and the new door.
I appreciate your help and counsel. Ill keep you posted whether it needed a new actuator door again or if it was an installation issue. Finally, I might even try flushing the radiator fluid if all else fails. Ill keep you posted.
Thank you!
SlickJonz (05-13-22)
Hi Iolmaster!
Thank you!
Thank you!
irieblue
RX - 3rd Gen (2010-2015)
08-04-08 11:32 PM
