unswitched 12 volt supply in cabin???
8th Gear
I did try searching for a thread on this but...…. Is there an un-switched 12 volt supply line already in the passenger cabin that can be taped/used for a dash cam???
If not, any suggestions on where/how to get 12 volts un-switched into the cabin without making a mess???
Thanks, Ron
Thanks, Ron
Go to the fuse box under the driver side of the dash, to the left of the steering wheel. Inside of the lid is a guide to the fuses. You may have to lay on the floor with a flashlight to see it. One of the fuses should be to something that has power all the time.
Get a fuse tap on eBay to run a wire from it to where you want to dash cam.
I think some others may have accessed power from the area above the rearview mirror.
