2010 RX350 Rear Nozzle not Spraying
As the title says my RX350 rear windshield washer fluid is not spraying. Appreciate any guideline to troubleshoot.
Regards,
Bills
Regards,
Bills
Try a pin in the nozzle hole as it may be clogged. Then determine if the front sprays as they share the same reservoir and is it full of fluid. Next listen if the rear sprayer pump is working.
If not check the fuse for it before thinking about a new pump motor and it may share that with the front nozzles.
