No Power to Passenger Side Headlamp - Fuse Good
The passenger side headlamp on my 2010 RX 350 is out. I swapped the bulb with the driver side; the driver side continued to work and the passenger side continued to be out. I also swapped the fuses for the driver and passenger side headlamps, same issue. A volt meter showed no voltage to the passenger side headlamp socket. There is voltage to the passenger side headlamp fuse, so somewhere between the fuse box and the headlamp I am losing power. Any suggestions?
Do you have halogen or HID bulbs? H11 halogen or D4S HID. Could be a bad ballast for HID or relay for halogen.
There is a fuse box in the engine compartment. Under the cover is a map of the fuses and relays. It is also in your owners manual.
I would also check for corrosion on the bulb harness connections.
Because the socket could lose the ground connection due to corrosion, so make sure you have a good ground to the socket.
nbizzle
04-07-19 09:27 PM
boxed
06-14-14 03:15 PM
Sash1mi
02-06-10 01:29 PM
