Air conditioning problem
hi I’m new here and I just bought 2010 rx350and have a problem with air not working sometimes. Usually after I drive awhile then start back up. I took to dealer and had it gassed up ( 210.00). Still having issues. Any help would be great. Thanks
how soon after the dealer did you have the same issue. Any leaks?
You could go back to the dealer. Ask them what other tests they ran.
However read this thread first so you are aware of this A/C problem which has a very inexpensive fix as described in the last few pages of the thread. Basically you stick a magnet on an external switch and it makes the compressor stay on. Better than buying a new compressor from the dealer.
https://www.clublexus.com/forums/rx-...-solution.html
