Rear differential fluid capacity question
So I changed the rear diff fluid of my 2013 Rx with 77k mileage. It only took about .6 quart before the fill line was dripping. Is that ok? Most people say it takes .9 quart to fill. Car was level.
I don't mind if there is old fluid in there.
I just want to make sure I did not underfill it, since the old fluid didnt look that bad.
Can I assume since the fill hole was dripping that the fluid level is ok in the rear diff?
Yes. It has enough fluid.
donzoh1
05-22-24 07:47 PM
is250gurl
03-09-07 11:38 AM
