Power Liftgate Intermittently Working, Long Beep
Old 10-26-23 | 06:10 PM
  #46
RX350QQQ's Avatar
RX350QQQ
3rd Gear
Default Replace the Motor Brushes
The intermittent issue could be from worn out brushes inside the motor. That was my issue after I took it apart with the help of the video. I rebuild my motor with this ebay part. It fits and works on my liftgate.
https://www.ebay.com/itm/25627105010...mis&media=COPY
Old 10-26-23 | 06:28 PM
  #47
salimshah's Avatar
salimshah
Were your carbon brushes worn to minimum or chipped or were sticking?
Any issue with bearings?
Salim
Old 10-26-23 | 06:51 PM
  #48
RX350QQQ's Avatar
RX350QQQ
3rd Gear
One of my two brushes was cracked. That was the root cause. The other one was worn. The factory material seemed soft and could wear out overtime.
The liftgate motor assembly from my 2010 RX350. It lasted about 10 years.
salimshah (10-26-23)
Old 10-26-23 | 11:37 PM
  #49
RX350QQQ's Avatar
RX350QQQ
3rd Gear
Default Picture of my old carbon brush from my liftgate motor
I kept my one cracked carbon brush. It is too short to do its job. The other one was pulverized after I took it out. The motor bearing is fine.
Old 06-29-24 | 10:42 AM
  #50
infernophi's Avatar
infernophi
2nd gear
Originally Posted by 2013FSport
Resolved $466 later...
Investigation found the right motorized lift strut to be locked up in the hatch closed position.
Here are the steps used to fix it when your hatch is stuck shut:
Note 2017 Highlander XLE in this case.
Set the glove box button to disable.
From the inside, a panel on the hatch/rear door comes out with a soft pick and you can unplug the connector. Pop another small cover over the latch and trip the lever to open the hatch.
From here, I lifted the hatch a few inches, and shoved some gloves under the door to hold it open, then unplugged and pushed the cable through the hole in the door. Then I tried to pop the lift strut off the ball on the gate from the inside with a bit of brute force but No luck, the hatch remains closed only able to open it about 2 inches.
From the outside I used a 10mm socket/ratchet and extension to remove the top bolt. Then a pivot wrench to break the bottom bolt free (while forcing the gate open) for access as the angle is about a 45 degree shot between the body and the door and you're working in a narrow gap. To speed up the bolt removal, I slid a 10mm wobble socket in on a speed handle to remove the bolt and soon enough, the bracket was free and the rear door could be opened and propped up with a broom handle.
Unbolt the remaining bracket from the body, install the new one on top, install new bracket one on the lift gate. Raise the gate to full lift and pop the new lift motor on the top and bottom brackets. I added some synthetic grease to each socket as the oem left just a drop in each. Now feed the cable through the hole, secure the boot making a water resistant seal and plu in the connector. Install removed covers.
Remove the broom and pull gate to closed. It should lock on its own. Toggle the glove box switch and take the key fob to the back.
Upon button press, it opens and closes as it did before.
Time spent was less than 20min once I realized the lift strut was locked and not moving.
Wife got a quote for $2200 to replace both sides from an indi. What a crook!
FWIW Rockauto has the powered struts for like $140 less, but we're leaving Sunday and needed it fixed today.
And ya PN: 68910-09140 is $120 cheaper than the 68910-09120 that it needs and all because of JBL speaker option. wtf Toyota???
GL people...
Edit: cell phone post
still fixed? My 2016 is having the same issue. I think it’s the struts because it’s making the long beep not the glass sensor double beep.
Old 06-29-24 | 11:50 AM
  #51
2013FSport's Avatar
2013FSport
I wouldn't know. She was in a head on collision later that year and the Highlander was totaled. Keep in mind these were powered struts, not a central motor like many of the RX....
Do you have powered strut locked in place?
Old 06-29-24 | 01:07 PM
  #52
infernophi's Avatar
infernophi
2nd gear
Sorry to hear about the wreck. I hope everyone is ok.
It’s been difficult to recreate my issue. The trunk decides not to open sometimes. I thought it was the glass sensor at first, but that gives a different double beep. Mine does a long beep like it’s mad. I ordered the struts and I’ll report if it fixes the issue.
Old 06-30-24 | 05:29 AM
  #53
RX in NC's Avatar
RX in NC
Fingers crossed that new struts will indeed fix it.
pfloyd (07-01-24)
Old 07-31-24 | 02:56 PM
  #54
oshkalabah's Avatar
oshkalabah
I replaced the two struts on the back of my 2012 and I think it helped but did not fully solve the long beep intermittent opening issue. Does anyone have a (working) eBay or Amazon link for a replacement motor, or what else should I check?
ziomal
07-20-24 11:23 AM
AtlantaCPA
01-05-20 07:01 AM
sgmorton
09-06-14 12:11 PM
jarm
11-12-12 07:48 AM
eholody
07-25-06 11:07 PM
