Auto lights timing question. 2010 RX 450h
I park underground 2 levels below and the lights don't come on until I am almost about to park. Is there a setting where this is almost instant? Most my cars with this feature would turn the lights on when I entered the parking right away. I looked in setup but couldn't find it. Thanks.
You may just need to wipe off the top of your ambient light sensor. It is usually a small dark-colored dome up on top of the dash near the base of the windshield. It can also be mounted on the back of the rear view mirror. Once you find it, wipe it off with a soft damp cloth and see if that resolves your issue.
Salim
The sensitivity setting changes how dark it needs to be for the system to react.
It does not change how quickly it actually does react. The Navigation screen
will dim and brightly almost instantly but the outside lights and "green lantern"
dash icon are a bit more deliberate. Wouldn't want them flashing the lights driving
under every stand of trees, right?
They should. On my 2010 when entering my underground parking garage, right as I pass through the entrance gate, which is on a steep downhill slope, the lights come on. I have never touched the adjustment setting.
You pretty much described my garage. Exactly the same. My lights turn on after I go down one level.
msat
RX - 3rd Gen (2010-2015)
23
07-02-14 06:49 PM
