Centre brake light rear
Hi one of the bulbs in the centre brake rear light is not working.
Any tutorial about how to change ? And what type of bulb needed?
it’s rx 450H
many thanks
it’s rx 450H
many thanks
Its LED and you would need to replace the whole unit. As long as most of the bulbs work, I would leave it alone unless you have a tax refund you want to spend. I have no idea of the cost to replace it but suspect at least $200.
Here is an older thread about replacing it which provides instructions to do it yourself. Also in the US we spell it center.
https://www.clublexus.com/forums/rx-...placement.html
https://www.clublexus.com/forums/rx-...ake-light.html
This distressingly long procedure is for the newer 2016 generation but I looked up the 2010-2015 body
and it is similar. Final step (replace High Mount Light Assembly) is simple as is the 2nd to last step
(remove rear spoiler). It is the 27 step (Upper Back Window Trim) that seems extraordinary.
SC400_2nV
03-13-13 02:13 AM
