Lights On 2010 RX 450H keep going out
So for the past year and some change I've been having issues with the bulbs/ lights on my 2010 RX 450H so much so that the GM of the dealership I often use offered to intervene in Feb of this year but COVID showed up and I haven't been able to make it since. First my rear lights blew out on opposite sides so the left tail light and the right bumper then the right tail light and the left bumper then the right tail light blew out AGAIN and the dealership blamed it on a possible bad bulb and the advisor said there is no way it would blow again but it did. Bring it back they replace a wire in the right light and insist everything should be fine but it blows out again. Now, I also had the front Outter bulbs (the small yellow bulbs on the headlights) were replaced late last year and those are blown out. Then today I went to pick up pizza and noticed that one of my headlights was out. When I got home I turned the lights off and on and the light went back on. I'm going to give the dealer another phone call tomorrow any idea what in the world could be causing these bulbs to be constantly going out? Any thoughts is greatly appreciated
How long have you had the RX? If purchased used, do you know its history? Maybe it was flood damaged, or worse, salt water flood damaged.
If you got it used, check out its Lexus dealer service and repair history on this link, just join and enter the VIN
https://drivers.lexus.com/lexusdrivers/
360LexusEs
RX - 3rd Gen (2010-2015)
07-11-19 07:12 AM
