3rd Gen Tail Light Removal
Hi all
I am replacing my rear tail lights on my 2011 RX350. I have looked around the forum and youtube but cant find clear instructions on how to remove the tail lights. From what I have gathered so far, the tail light is held in by 4 10mm bolts with the point part of the tail light (closest to the rear door) being seated into a clip basically. I have opened the small access panel which would normally be used to change the light bulb and can see the 4 screws (1 appears tricky to get to). Is this the only means of getting to these bolts? It looks as though I would also potentially need a deep socket to get around the length of the bolt itself?
Look at the thread on Crystal Eye taillights on the first page of this forum as it contains posts describing installation which would apply to your situation
https://www.clublexus.com/forums/rx-...il-lights.html
Also this older thread on Meteo taillights
https://www.clublexus.com/forums/rx-...-10-15-rx.html
