AC blows hot air
AC blows hot air
Hey everyone. I have a 2014 RX350. On Tuesday we had strange weather (Virginia) and I ended up turning on my heater on the way home (cold and rainy). Parked it while heater was running. Went to drive today (Thursday) and it's 90 degrees again. Turning down the temp doesn't do anything and it just blows hot air. I cycled thru all temp settings and turned on/off. Fuses all look OK. I'm going to pick up a pressure gauge tomorrow to check pressures.
Any ideas considering I switched it to heat this week? I didn't turn the AC off when running the heat so I'm wondering if there is some electronic control that's stuck.
Thanks!
Thanks!
I do not hear the compressor turning on, and the low pressure port reads in the red which suggests the compressor is not turning on. I read about the magnet trick on the 2010-11 RX350s, but I can't find anything that suggests it would work on a 3rd Gen. Maybe I'll give it a try this afternoon. Unfortunately for me, there doesn't seem to be a lot of AC issues for the 3rd Gens (good for all). I'll continue to hunt for instructions on how to further diagnose.
Thanks again
Thanks everyone!
I'm trying to upload a pic in case it helps. Take the skirt off the bottom of the car, and you're looking up at the bottom of the compressor. The red arrow shows where you put the magnet. Up just over the connector, and it sticks.
Thanks again everyone!
zmel (09-05-20)
Koz1614
09-13-19 02:35 PM
