Aftermarket Wheel
Aftermarket Wheel
I recently purchased a 2015 Lexus RX350 AWD Starfire pearl with 19 inch wheel. I am thinking about upgrading to 20 inch wheel. Do you think 20x9 et38 wheel with 265/45/20 would fit the Lexus? Thanks in advance.
Look at the Tools section in the top black line above. The drop down menu contains a tire rim calculator that you can use to figure this out yourself. There are many others online. Or call the folks at Tire Rack.
Thanks for the response, Clutchless. I tried using the tire rim calculation but I didn't understand if the 20x9 et38 would be to wide? I do not want to use spacer. I just wanted to know if the 20x9 et38 would rub against the suspension?
You can try this link https://www.wheel-size.com/calc/
Also see this old thread and read all of it https://www.clublexus.com/forums/rx-...r-2014-rx.html
ap0718
Wheels, Tires & Brakes Forum
23
09-13-23 03:48 AM
