Tail Light Assembly 2013 RX350
Hi - the tail light assembly on the driver sdie fo my 2013 RX350 was cracked. Bought a new one online and just installed it (bloody knuckles to prove it). The light does not work - and when I re-attached the old one, it didn't work either. The blinker and reverse bulbs are fine - just the light that turns on with the headlights is not working. Do I need to reset it somehow? Thanks for your help!
First things first - remove the bulb and closely inspect its filament. If it looks intact, clean and burnish the socket in the assembly, reinstall the bulb, and see if it now works.
