Rear differential fill plug part number?
As title states, does anyone have the part number on hand?
I was starting to change out the rear differential fluid but stopped since I'm pretty sure I'm going to need a new one. My 10mm hex is really doing a number on the head of the bolt.
Start spraying it with PB Blaster then give a couple of days to soak in.
90341-18034 rear filler plug
and the same parts fit both Japan and North American built models
12157-10010 plug gasket
90341-18051 drain plug
You can look it up yourself here,
https://www.lexuspartsnow.com/parts-...ferential.html
thisguy_06 (10-15-20)
Thanks so much for that.
Salim
