Low Engine Oil Pressure - 2010 RX350
Just purchased my first Lexus this July... a 2010 RX350 AWD. No problems until this afternoon when the “low engine oil pressure” warning light started flashing and the engine started to make a strange noise (sounded like I was revving it and it was struggling to accelerate). Pulled over and AAA towed it 70 miles to my local Lexus dealer. Won’t hear from the dealer until tomorrow—does anyone have an idea of what this could be? What should I expect to pay for this to be fixed?
Let them diagnose.
Red light and flashing red lights mean pull over and shut down the engine and then do the checks ... engine oil level/oil-leak.
If the engine was not shut down quickly, there may be damage due to low pressure. If it was shut down soon enough, quart of oil and repair of the source of the problem is all that needs to be done.
Salim
Salim
Thank you! I noticed the message pop up on the dash a while before I pulled over, but it kept disappearing before I could read it. I also noticed that the entire rear of the car was covered in some sort of liquid... I’m now assuming it was oil. I pulled over once I read what the warning message said, which was right after the vehicle started to make a revving type noise.
I wonder if you have the tow package and your oil cooler rubber line burst causing all the oil to leak out very rapidly. This hose is known to fail and Lexus has a replacement metal line. They even provided an extended warranty on the line itself, but I am not sure if it includes engine replacement. They sent out notices and there probably is a TSB, technical service bulletin. I recall the warranty went to 150,000 miles but am unsure of the time limit. If you have issues with them, try contacting Lexus corporate. If you have had your service always done by a dealer they will be more inclined to help.
See this thread for more information https://www.clublexus.com/forums/rx-...ne-advice.html
RX10 (11-19-20)
I do have the “tow prep” package. The tow truck driver was able to move it off of the truck and into a parking spot under its own power, so I’m hoping the engine is still operable today. I read about that warranty online but, if I remember correctly, I’m past the point of coverage (10 years from original purchase date or 150,000 miles). I only have 107,xxx but I believe the original owner purchased in 2/2010.
Since you just bought this last Summer you should check the maintenance and repair history at the official Lexus Drivers Site via the link below to the Lexus Drivers Site. Its free. Join and enter your VIN, then you can access the maintenance and repair history, plus list of factory options etc
https://drivers.lexus.com/lexusdrivers/
I don't own the same model, but could this be the infamous rubber hose issue.
Salim
Salim
Thanks everyone. No major engine damage! It was an oil cooler line leak. Dealer said my “recall warranty” expired earlier this year. Unfortunately, somehow the water pump is now ruined and they recommended putting a new drive belt on it as well. All in about $1700 worth of work—UGH! First Lexus I have ever owned and purchased only 4 months ago.
By the way, both the oil cooler and water pump leak have been discussed here in Gen3 forum.
Salim
You purchased a ten-year-old vehicle. There are always issues with any vehicle that old. What you hope for is that the issues will be relatively minor.
Which North Carolina Lexus dealership are you utilizing?
That’s a good point. I didn’t expect it to be “problem free” but a $1700 repair bill is kind of excessive on a $14000 vehicle. I have been using Hendrick Lexus Charlotte. Great, friendly staff. Just a little bit aggravated at the repair bill.
In your case the gasket most likely is cheap but the time required to replace is high and the dealership is charging premium labor rates. In old days the serviceability was a major design factor, but these days there are other factors ... including higher reliability. But the manufacturer makes a mistake here there ... and are more focused on lifespan within warranty period. I have a 98 GS400 and the starter solenoid contacts wore out. The parts are less than $10, but to get to the starter, the whole intake has to be removed ... 8hrs of labor.
My understanding is that the engine has to be removed to service the coolant leak you are experiencing.
Salim
