Waterpump replacement
Yes you should do it and they need the car to be cold to accurately measure the fluid drained and the amount poured back in. So you must leave it overnight. That is how I do it myself.
In the fine print in the maintenance record manual, it states that under severe duty conditions such as towing, etc you should change it at 60,000 miles.
Lexus does not care if it breaks down after the warranty is over and they no longer have to pay to repair it. Most will last 100,000 without a fluid change. If you want to drive it longer without any problems, then change your transmission fluid now.
allendsup2 (12-29-20)
I agree with Clutchless. Manufacturers are saying "lifetime fluid", but they don't bother to define "lifetime" to the general consumer. It means "for the life of the warranty".
I bought my 13RX with 65K miles, and I flushed my trans (myself) at that time. The ATF was darker than new, though it was not black. I used Toyota WS ATF. Its a more complicated procedure to set the level than old school trans with dipsticks. I found I had to purchase the genuine toyota manual to get the correct procedure, but it can be done DIY.
I also changed the rear diff oil, and the front diff (ie "transfer case"). Those 2 are very easy to change compared to flushing the trans.
I have around 77K miles now, with no issues. I plan to flush my ATF every 40 to 50K miles. I tend to keep cars a very long time, averaging 16-17 years.
allendsup2 (01-04-21)
It is a good idea to change the transfer case and rear differential oils at your mileage considering they probably have never been changed. As AlgoTrader stated, they are easy to change and I will add that the cost is far less expensive to change them as both are simple drain and fill procedures.
These waterpumps are overbuilt. I have org fluid and pump at 98k. 2010. Getting ready to replace antifreeze. As far as the pump i have no worries unless it starts leaking out of the seep hole. I have seen 200k miles on these pumps. I have done nothing to this RWD RX350 except regular maintenance .No plugs, coils etc. But plugs soon at 100k. clean PVC valve.
allendsup2 (01-11-21)
Referral
Hey Clutch and Allendsup…first and foremost thank you so much for sharing the Carspec folks. Problem is they are so popular now they don’t take new clients without a referral from current customer. Hoping and praying you could help a brother out. Looking for help on a RX350 ( yup, water pump) and a Camry my 18 year old can’t stop breaking. Please advise if you would be willing.
However, compared to many other makes the OEM Toyota water pumps are still better; since some of the other automakers have water pump issues even before 100k miles as a norm.
I still will check for weeping(pink residue) and plan to change out a RX350 water-pump by 200k miles.
Did you own your RX350 for the whole 250k miles? The original water-pump may have been changed before you purchased your RX.
Of course. There is always someone on a forum that claims that their engine never fails or is special. Trust me; the water pumps in our engine start leaking(or weeping )as an rule by 200k miles. However, I cannot say that all RX350 water-pumps will leak and many can be leak free over 200k mile like you claim yours is.
You can use this database of recommended repair shops from listeners of the old Car Talk car repair radio show, then cross check on Yelp or Google for more current info.
https://www.cartalk.com/mechanics-files
I have been part of many many forums over the years and there is always members who claim their cars never have problems even when everyone else does have similar issues. Not saying it cannot happen, but it gives a false sense of security for many owners that probably should be aware of an issue.
With that being said; you are only just stating that your water pump is still good at 250k miles so maybe there is hope that a RX350 water pump can go well over 200k miles with out any leaks or bad pulley bearings.
FYI the water pump on my 2016 Sienna failed at 37,000 miles and it has the same 2GR-Fe engine as the RX. It did not leak, but had an internal seal failure so it sounded like marbles rattling in a can, which was my clue that something was wrong. Point being that anything can fail on any car at any time.
carguy75 (05-05-24)
