Cigarette lighter ports in console not working
Is there a fuse for these things? Happen to know which fuse/location? I hope that’s what it is bc swapping these things out would be a PITA...I can barely get my hand in the console to begin with. Damn I wish that lid opened to 90 degrees...what a lousy design.
Correction: one lighter port works. One does not. Odd.
You must have a 2010 as that is the only year that lacked outlets outside the console box. If one works and the other does not, and the fuse is okay, your most cost-efficient way to fix this may be to get a 1 into 2 outlet expander.
There is a fuse box under the dash to the left of the steering wheel. You have to lay on the floor and look up (use your phone flashlight). The cover snaps off and inside the cover is a guide as to which fuse covers which part.
carlos
11-06-07 11:09 AM
