2010 Nav Question. Split screen specifically
I don't know what specific version of maps I have but is there a way to split the screen where one half is map and the other half is audio? I recently came across a 2010 RXh for sale where I saw a picture with exactly that but I cannot replicate on mine.
Does an update give this ability? Thanks.
NickSP (06-27-21)
Can you please explain/elaborate on "audio" in the other half. Are you interested in the radio/song/source/track info?
Pictures posted are showing next exit info and when you are navigating (destination programmed) that half zooms in to the intersection map.
Salim
Salim
That's right Salim. I want the other half to show Audio info like track played, etc. Is that possible?
I posted those pictures of my screen showing my split screen Navi. I too am confused by the audio thing. If your trying to split your screen so half can be half navigation and the other half hvac/radio/menu that’s only on the current generation RX with the wider screen.
Salim
NickSP (06-28-21)
While the RX did not get the Map + Audio split screen configuration until 2013 you can toggle
between Map and Audio by pressing the center console Map button and then the dash media
choice (AM, FM, CD, Sat, Aux) button.
Thanks for that tip and I'm aware of that. But it's extremely stupid of Lexus to do this when the hardware is practically the same.
2013's also was the first to be able to pair the Bluetooth for both phone and contacts and music in one
operation. While the 2010 - 2012's were an upgrade from the phone only 2009's and earlier you must pair your
phone in two steps to enable the media. You also must trigger the contact update in the car when you
add entries to the phone. New models do that automatically with a brief delay in being able to use the
voice command while it happening.
