Drive Belt and Engine Oil cooler line
Replaced both for preventative measures and the RX being 11 y/o at 95k, not bad. As for the drive belt, that's the only worn part.
The following 2 users liked this post by happy1977:
Clutchless (01-18-22),
Hayk (01-18-22)
mwengineer (02-05-22)
Good call on the oil pipes/tubes.
Don't you follow the suggested maintenance in the warranty and service handbook? If not then there might be more than the belt that needs replacement.
Salim
Salim
I try to. Just had the spark plugs replaced, differential oil replaced, transmission oil replaced last year. I'll look again to see which one I need to address as planning on keeping this RX for another 4 years before wifey gets a new one.
SNiiP3R
11-04-15 01:05 PM
