Sounds Quality
Sounds Quality
i have a 2013 with a factory sub. It sounds good when i play the radio but when i connect via BT and listen to spotify there's not much base. Any way to improve this?
From older posts it appears your phone is only paired as a phone and not as a music/media player although it is supposed to be automatic for both on a 2013. See below.
2009 Lexi only paired BT for the phone, no media connection or USB jacks.
2010 - 2012 Lexi have BT for both phone call and media but you pair them separately
2013 and newer pair the BT and it connects for both automatically.
OP - press menu on the center console and set up on the screen. You have already
been here and selected phone to pair for calls... Now select Audio and pair your phone again.
Note: the car will pair with up to four (4) phones and up to two (2) media devices, your phone will be both.
Check for previously paired devices and remove at least one to make a slot available.
Be certain your phone volume is at least 1/2 up to provide adequate sound.
The 2010 does not have Siri Eyes Free but if you "illegally" reach over and press the
appropriate phone button you will hear the trill and can proceed to text by voice, command
iTune tracks by Artist or Song, etc.
https://www.clublexus.com/forums/rx-...ooth-siri.html
https://www.clublexus.com/forums/rx-...th-issues.html
https://www.clublexus.com/forums/rx-...on-t-work.html
https://www.clublexus.com/forums/rx-...d-threads.html
ShiftyD2k
04-06-15 02:23 PM
