P0161 code. Questions regarding bank 2 sensor 2 location and recommended part.
10th Gear
I know bank 2 sensor 2 is after the cat but I'm not sure if it is on the driver or passenger side. The brand I've seen recommended to replace it with is Denso. Problem is 1) as stated I'm not sure what side and even if I did 2) rock auto shows the Denso sensors as downstream left or right instead of the bank and sensor number. I'm not sure if left is supposed to be driver and right is passenger. Any help would be appreciated. The only answer I've seen is from a short youtube video saying bank 2 sensor 2 is on the driver side but I'd really like to confirm this with another source. Thanks.
This has been asked, answered, and discussed many times.
I will help you help yourself by providing a link to search results regarding oxygen sensors. Your assignment is to read the linked threads to find the info you need.
A drawing of their locations etc is in one or more of the threads.
Good Luck.
https://www.clublexus.com/forums/sea...rchid=25036858
Good Luck.
Do a search using the term "Oxygen sensor" in quotes so you search the phrase. Those search results were supposed to be in the link.
You could also try "02 Sensor"
You could also try searching the error codes individually
10th Gear
Thanks. Its a little difficult to sift through the threads to find an exact answer but I did find a tip to run some techron in the tank which may clean up enough gunk to stop the CEL. Thankfully the code is off for now but I'll be still looking into it in case more action is needed. I suppose I'll document my findings here if that's the case.
There is no reason why Lexus would switch, but for sure in first Gen RX ,,, the engine is mounted transverse with bank1 near the firewall and bank2 near the front. Cylinder 1-3-5 are near the firewall and 2-4-6 near the radiator. For post combustion, follow the exhaust plumbing.
Salim
Salim
Argh! Left and right are very confusing terms. They make more sense in a front to back engine. With transverse mount engine, due to rotation it gets confusing [Well if you have the right (proper) perspective it should not matter].
Saliim
Saliim
10th Gear
Update. Put the part in yesterday. If I'm correct the b2s2 location is near the exhaust pipe between the front wheels. Laughably I'm still unsure if it's fixed now because my obd2 reader decided now is the time to quit. I literally cleared my code a couple weeks ago and now will have to wait until I can get the keys from my wife to take it to an auto store for them to clear it for me. I'd rather do that then disconnect the battery. Will follow up after the codes are cleared.
